Engine out practice
Old November 5th 07, 05:52 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Default Slips with Flaps, was: Engine out practice
"Newps" wrote in message
Dan Nafe wrote:
Bertie the Bunyip wrote:
An old rule-of-thumb I remember has it that aligning the flap with a
down aileron gives you the best (most lift) flap position (assuming, i
presume, that the ailerons deflect to maximum effectiveness=lift)
Never heard it but it sounds like a good bush piloty sort of thing to do.
My flight instructor, a former drug-smuggler, taught me that very
technique.
The most lift is always gained with the most flaps.
I try to shy away from the use of the word "always". There are some
aircraft that use flaps for their induced drag. An example is a glider with
large span 90 degree flaps. As an owner of such a craft I can testify that
increased lift is not associated with flap setting greater then 40 degrees.
Setting beyond 45 definitely exist only for the drag they create.
(http://tinyurl.com/2w6fuk)
HP-14 "6F"
http://www.soaridaho.com/Schreder
  #152
Old November 5th 07, 06:08 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Steve Hix
technique.
Really?
Even if true, you sometimes end up picking up drag faster than increased
lift at extreme flap settings, depending on the aircraft.
  #153
Old November 5th 07, 11:53 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Newps
Really?
On your typical Cessna 152, 172, 182 206, etc the most lift for the
least drag is approx 20 degrees. Flaps at 40 degrees gives you the most
lift but also more drag than at 20 degrees. Just depends on what you're
trying to accomplish. The first 20 years of Bonanza production there
wasn't a flap indicator in the aircraft, don't have one in mine. The
factory put a stripe that you could line up with the trailing edge of
the wing to get 20 degrees. Those disappear with the first paint job.
  #154
Old November 6th 07, 03:28 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Roger (K8RI)
On Mon, 05 Nov 2007 16:53:42 -0700, Newps wrote:
Really?
One thousand one...Onethousand two...onethousand threee...
Who needs marks or indicators?
Roger (K8RI)
  #155
Old November 6th 07, 05:21 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Rich S.[_1_]
I'll bet there's a Gummint regulation that sez you can't hide that stripe.
Rich S.
  #156
Old November 9th 07, 03:07 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Dan Nafe
Rich S.
I re-marked mine with a Sharpie.
Topi - Mig29 engine failure during practice - "topi.wmv" (14/26) 6.0 MBytes yEnc Immaterial Aviation Photos 0 January 6th 07 09:15 PM
Topi - Mig29 engine failure during practice - "topi.wmv" (13/26) 6.0 MBytes yEnc Immaterial Aviation Photos 0 January 6th 07 09:15 PM
Topi - Mig29 engine failure during practice - "topi.wmv" (11/26) 6.0 MBytes yEnc Immaterial Aviation Photos 0 January 6th 07 09:15 PM
Practice Engine-Out Landings Jay Honeck Piloting 52 July 14th 05 10:13 PM
A PIREP: engine-out turn-back - some practice in the haze Nathan Young Piloting 15 June 17th 05 04:06 PM
