headset feedback loop during xmit
Old May 16th 09, 09:24 PM posted to rec.aviation.owning
Mike Noel
Default headset feedback loop during xmit
Telex (evidently now owned by Bosch) fixed the Stratus 30 under warranty and
it's working well. They replaced a circuit card and the mic. The service
people were friendly and the turn-around including shipment and repair took
2 weeks.
In the interim I purchased a Lightspeed 20 xlc so I could have ANR for 3
seats in the plane. The Lightspeed is nice, but I prefer the Telex (which I
had upgraded with 30xt cushions) since it puts less pressure on my head.
The adjustable clamping force cams are a nice feature on the Stratus line.
Can the Lightspeed's head-band be safely bent to reduce the clamping force?
Best Regards,
Mike.
http://flickr.com/photos/mikenoel/
"Mike Noel" wrote in message
My Telex 30 headset and SL30 nav/com have developed a loud and annoying
oscillation during xmit. The tone is both obvious in the headset
side-tone
and also is heard by other's listening on the frequency.
I've tried two other headsets (a DRE ENR and a non-ANR headset) and both
work fine with the SL30. My com2 is a King 97a and it works fine with all
of my headsets, including the Telex.
The problem seems to have developed in stages over the past several
months.
First I was noticing the Telex and SL30 would occasionally give my voice a
hollow sound for the first few transmissions of the day, then sound fine.
Finally last week the tower controller mentioned the squeal which I was
also
noticing. It tends to go away after a bit but it sounded odd for the
entire
flight.
Has anyone experienced a similar problem? I'm hoping to try a few other
brands of headsets this weekend to see if the headset is the likely
culprit.
Best Regards,
Mike.
Old June 12th 09, 11:10 AM posted to rec.aviation.owning
Dennis[_7_]
hello,
you tray to this http://www.cordless-phones.uk.com/headsets/
2 weeks.
Best Regards,
Mike.
http://flickr.com/photos/mikenoel/"Mike Noel" wrote in message
side-tone
I've tried two otherheadsets(a DRE ENR and a non-ANR headset) and both
of myheadsets, including the Telex.
months.
also
entire
flight.
brands ofheadsetsthis weekend to see if the headset is the likely
culprit.
Best Regards,
Mike.
Alternator noise on Xmit only Vaughn Simon Owning 7 July 2nd 08 08:22 PM
outside loop niceguy Aviation Photos 13 August 9th 07 06:57 AM
My Ground Loop Reid & Julie Baldwin Piloting 53 December 5th 05 11:29 PM
More likely to ground loop? [email protected] Piloting 16 February 25th 05 03:21 PM
AN-2 performing a loop Maro_SK Aerobatics 1 March 25th 04 08:18 PM
