Curtis oil quick drain
Old August 25th 09, 08:01 PM posted to rec.aviation.owning
Mike Noel
Default Curtis oil quick drain
We need to replace the quick drain on the bottom of our Lyc O-360-A1A. The
valve for the application is the CCB-37000. Does anyone know the correct
torque and any recommended thread sealant?
Best Regards,
Mike.
http://flickr.com/photos/mikenoel/
Old August 26th 09, 01:34 PM posted to rec.aviation.owning
On Aug 25, 1:01*pm, "Mike Noel" wrote:
We need to replace the quick drain on the bottom of our Lyc O-360-A1A. *The
valve for the application is the CCB-37000. *Does anyone know the correct
Best Regards,
Mike.
The Lyc manual says 160 inch pounds for a half-inch pipe plug,
which is what that fitting should be (pipe is measured internally; the
thread itself will be around 3/4" or 7/8" OD). That's 13.3 foot-
pounds. A lot less than most guys will wind up on it. I use Permatex
Form-A-Gasket as a sealant. Don't use teflon tape.
Dan
Old August 26th 09, 11:04 PM posted to rec.aviation.owning
Mike Noel
Dan, thanks.
Best Regards,
Mike.
Best Regards,
Mike.
Dan
Curtis Hawk Glenn[_2_] Aviation Photos 2 September 14th 08 08:31 PM
Limiting battery drain by using what? joesimmers Soaring 2 July 23rd 08 02:31 PM
Curtis quick drain keepitrunning Home Built 4 December 26th 05 02:50 AM
Quick drain mess. dlevy Owning 10 October 17th 05 01:55 AM
sump drain cleaning Mike Noel Owning 15 August 15th 03 02:41 AM
