"Bruce A. Frank" wrote in message Jim, The suggestion of how to fabricate an inexpensive fresh air mask is a good one, but don't be afraid of single or twin cartridge respirator masks. I'm not afraid of resirators, and only use fresh air systems when using the nasty stuff, like the two part urethanes. The one disadvantage I find with the fresh air mask is having to deal with the hose following me around as I duck and bend to shoot paint on all the parts. I solved this problem by attatching the hose to my belt, mostly around my backside. It wasn't much in the way, like that. I improved my home made system by using small tube from my compressor, 1/4", at 90 psi to an adjustable valve attached to my belt. From what I have read, that is a very risky thing to do. The air from a standard air compressor has oil vapors, and things in it that you should NOT be breathing. At very least, I would send the air compressor air through a organic cartridge, before breathing it. Epoxies an solvent based paints are completely filtered by the charcoal type organic filter cartridges. Yep. Good to see you back in the funny papers. How is your project going? -- Jim in NC |
Morgans wrote: Good to see you back in the funny papers. How is your project going? -- Jim in NC Well, I have quit my day job to concentrate on building fuel tanks for homebuilts. Since I am way behind on tanks, about 8 weeks right now, progress on my project is slow. Lot of happy customers though! And I really am enjoying doing this!! Still trying to get the next issue of the newsletter out. -- Bruce A. Frank ====================== Aircraft Projects Fuel Tank Fabrication TIG, MIG & Oxy/Acet Welding & Brazing |
"Bruce A. Frank" wrote Well, I have quit my day job to concentrate on building fuel tanks for homebuilts. Since I am way behind on tanks, about 8 weeks right now, progress on my project is slow. Lot of happy customers though! And I really am enjoying doing this!! Still trying to get the next issue of the newsletter out. -- Bruce A. Frank Fantastic job change! I was going to say that I didn't know you were doing that, and ought to spam us a little, but then...* weeks behind, I guess you don't need to get 10 weeks behind! -- Jim in NC |
On Mon, 17 Jan 2005 12:21:57 -0600, Jim Carriere
wrote: Hello group, Who here has worked with MEK and other wonderful solvents? Where did you get your respirator gear from, and what models? The filter ones available in the chain "hardware" stores have fairly vague specifications on the labels: usually suitable for aromatics, solvents, etc. This is not something I wish to leave up to chance. Do I need to fork over the big bucks on this one and pay for a forced air system? When I put 3 coats of 2-part epoxy paint on the floor of my shop I didn't have the equipment I have now. Sooo... I took a standard face shield, one large garbage bag, two lengths of the cheap 1 1/4 or 1 1/2 bilge (sump pump hose) and a squirrel cage fan I had on hand. I put the face shield inside the garbage bag, taped it to the inside of the bag, cut out the bag for the face plate, I taped the corrugated hose in position on my back with one piece of duct tape around my waist and another just under my arms. This left the hose open at the back of my neck and blowing up and over the top. The fumes were so strong you would have needed a full face mast any way. Using this set up I was able to give the floor three coats of epoxy. It did take several garbage bags as they are not the most sturdy things in the world, but I did have fresh, clean, COLD air. Total cost was less than $10 as I had the face shield on hand. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Thanks in advance. |
Very innovative! Showing way too much common sense!
Roger wrote: On Mon, 17 Jan 2005 12:21:57 -0600, Jim Carriere wrote: Hello group, Who here has worked with MEK and other wonderful solvents? Where did you get your respirator gear from, and what models? The filter ones available in the chain "hardware" stores have fairly vague specifications on the labels: usually suitable for aromatics, solvents, etc. This is not something I wish to leave up to chance. Do I need to fork over the big bucks on this one and pay for a forced air system? When I put 3 coats of 2-part epoxy paint on the floor of my shop I didn't have the equipment I have now. Sooo... I took a standard face shield, one large garbage bag, two lengths of the cheap 1 1/4 or 1 1/2 bilge (sump pump hose) and a squirrel cage fan I had on hand. I put the face shield inside the garbage bag, taped it to the inside of the bag, cut out the bag for the face plate, I taped the corrugated hose in position on my back with one piece of duct tape around my waist and another just under my arms. This left the hose open at the back of my neck and blowing up and over the top. The fumes were so strong you would have needed a full face mast any way. Using this set up I was able to give the floor three coats of epoxy. It did take several garbage bags as they are not the most sturdy things in the world, but I did have fresh, clean, COLD air. Total cost was less than $10 as I had the face shield on hand. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Thanks in advance. -- Bruce A. Frank, Editor "Ford 3.8/4.2L Engine and V-6 STOL Homebuilt Aircraft Newsletter" | Publishing interesting material| | on all aspects of alternative | | engines and homebuilt aircraft.| |
On Fri, 21 Jan 2005 16:47:23 GMT, "Bruce A. Frank"
wrote: Very innovative! Showing way too much common sense! Thanks. I'll have to put up a link to a photo of the shop floor *before* it was covered with "stuff" and scuffed and had heavy, hard stuff with sharp corners dropped in places. G Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Roger wrote: On Mon, 17 Jan 2005 12:21:57 -0600, Jim Carriere wrote: |
Well Jim what I did was to buy a surplus gas mask from Sportsman guide
and then went to a junkyard and got a used heater blower from a car and then hooked it up with a hose.Put the blower in clean air outside the work area and attach to a car battery and it will feed clean air into the mask.I have been doing this for years.Jim in Ct. |
