Tail slat question
Old February 12th 04, 10:54 PM
Guy Alcala
Default Tail slat question
Ed Rasimus wrote:
On Thu, 12 Feb 2004 21:16:48 -0000, "Jim Doyle"
Hello all,
Just a quick question - do any aircraft have slats installed on the leading
edge of the horizontal tailplane?
Rather like slats would be used on the main wing section but - instead of
providing helpful lift - they're just to counter a very large pitching
moment on approach when wing-mounted high lift devices are deployed.
Can't comment on slats, which implys to me moveable. But, the F-4E at
slots on the horizontal tailplane--fixed sections about two inches
extended from the leading edge of the tailplane sections and running
the entire length.
The slotted slab was one of the mods necessary to compensate for the
longer nose and forward weight addition of the gun. A #7 fuel cell was
added in the tail cone to increase extreme aft weight and the fixed
slots were added to the tail plane to provide increased aerodynamic
downforce to counter the nose gun.
Ed, I tend to doubt the extra forward weight was responsible for the fixed
inverted slot (not slat) on the tail, as the navy's F-4J, with the short nose
and No.7 tank, also had it from the beginning, indeed before the F-4E entered
service. The F-4J also removed the inboard section of the LEFs and had drooped
ailerons, so that may have had something to do with it, but I'm cross-posting
this to r.a.m.n. to see if anyone over there knows why.
Guy
Old February 13th 04, 02:33 PM
Pechs1
Guy- The slotted slab was one of the mods necessary to compensate for the
downforce to counter the nose gun. BRBR
F-4J/S also had a slotted stab and tank 7-no gun tho..Hawg-10 was heavier than
the APQ-72 tho.
Inboard leading edge flaps were a maintenance nightmare. I think tank 7,
slotted stab, aileron droop, bolted up inboard LE flaps, all were running
changes to make the A/C better around the boat, as it got heavier.
P. C. Chisholm
CDR, USN(ret.)
Old Phart Phormer Phantom, Turkey, Viper, Scooter and Combat Buckeye Phlyer
Old February 14th 04, 08:56 AM
Guy Alcala
That was Ed, actually. My comments followed his.
the APQ-72 tho.
P. C. Chisholm
CDR, USN(ret.)
Thanks for the info.
Guy
Tail flapper failure Veeduber Home Built 2 May 22nd 04 06:52 AM
Tail slat question Jim Doyle Military Aviation 35 February 15th 04 08:37 AM
twin tail questions Kevin Horton Home Built 12 January 2nd 04 03:21 PM
T Tail question Paul Austin Military Aviation 7 September 23rd 03 06:05 PM
The prone postion for tail gunners versus turrets. The Enlightenment Military Aviation 8 July 22nd 03 11:01 PM
