Icom A5 headphones wiring?
Old May 12th 21, 06:45 PM posted to rec.aviation.soaring
Moshe Braner
Default Icom A5 headphones wiring?
Does anybody know how to connect headphones (listen-only) to an Icom A5
handheld radio? It has a 3.5mm (1/8") jack, but the official thing to
plug in there is an adapter for aviation headsets (including mic & PTT),
and the plug of that adapter has 4 wires (tip & sleeve and 2 rings,
looks like an iPhone connector). Can I plug headphones into it, without
bypassing the internal mic & PTT? I'd build the needed adapter if
necessary, but need to know the wiring diagram. But if the physical
presence of the plug in that socket disconnects the internal mic & PTT
then the answer would be "no".
Old May 12th 21, 11:00 PM posted to rec.aviation.soaring
Tim Newport-Peace[_7_]
handheld radio?Â* It has a 3.5mm (1/8") jack, but the official thing to
looks like an iPhone connector).Â* Can I plug headphones into it, without
bypassing the internal mic & PTT?Â* I'd build the needed adapter if
necessary, but need to know the wiring diagram.Â* But if the physical
I don't have the wiring for A5, but as it is a combined mic/speaker plug
the probability is that the presence of plug will disconnect internal
microphone. Other models have separate sockets for microphone and
speaker and therefore what you want is then possible.
FS Cheap Icom PW-1 1KW,Icom ID-1,IC-92AD,IC-756PRO III g0iqn Aviation Marketplace 0 July 1st 12 08:33 AM
Help with ANR Headphones [email protected] Piloting 22 May 21st 05 02:46 AM
FA: Sigtronic S-40 Headphones Bob E. Aviation Marketplace 0 September 27th 03 09:04 PM
Icom CM-35 Desktop Battery Charger for Icom IC-A2 Radio A. Kay Aviation Marketplace 0 August 23rd 03 08:01 AM
Headphones For Passengers Scott Lowrey Piloting 2 August 20th 03 06:12 AM
