Battery and Vacuum pump
Old January 15th 04, 08:13 PM
PaulaJay1
Default Battery and Vacuum pump
My battery is 3.5 years old and the vacuum pump is going on 350 hours. Both
are doing OK as best I can tell. What is the collective opinion reguarding
replacement of each of these? The factory recomended replacement time for the
vacuum pump (Aero Accessories AA-215CC) is 1200 hours but the old one (Sigma
Tek) sure didn't last that long.
Chuck
Old January 16th 04, 02:14 AM
dutch
I'm in about the same boat with my annual due this month. Since I have
nasty IFR here in the Great Lakes region, the vacuum pump is going to get
replaced for sure. I'm tempted by the dual pump and the wet pump, but they
are both really expensive, and I don't fly enough to justify it.
The battery is cranking fine on cold days so I plan to try for one more year
on it.
"PaulaJay1" wrote in message
Both
reguarding
(Sigma
Chuck
Old January 16th 04, 12:49 PM
CriticalMass
Pump - Do you fly IFR? If you do, I would replace prophylactically at
500 hrs. If VFR only, use it till it breaks.
Battery - Same question, if you fly IFR, replace it now. VFR, use it
till it quits, or replace it at your convenience. My personal opinion
is that you're living on borrowed time now. Conventional lead-acid
aircraft batteries don't normally last much longer than yours has.
Old January 16th 04, 04:22 PM
Dave Butler
I have the dual-rotor vacuum pump from aeroadvantage.com and I'm happy with it.
It's going to cost you about $1000 but you keep your existing, working pump, so
you have a backup in the baggage compartment. If you replace your pump with the
standard pump, it's going to cost you a good fraction of that, and you'll have
to turn in your old pump. Get the dual-rotor pump.
Dave
Remove SHIRT to reply directly.
Can vacuum AI be removed if a certified electric one is installed?? Dave Owning 11 January 12th 04 06:08 PM
NACA duct ventrui Chris W Home Built 7 October 27th 03 04:11 PM
