XC soar not logging igc file
last 2 flights I've had with the latest version of XC Soar (runs on
the memory card) have not been logged properly for some reason. When I try to upload to OLC it says it is an invalid file. Also am not able to replay the file on the PDA using the flight replay function. The file extension is not showing up as a .igc file! Any ideas for what the problem may be!!! Luckily I did set my GPS to log todays flight and that was able to be converted and uploaded. Thanks, Brad |
Brad
have you turned the logger on in the setup menu? Best wishes JohnR-K |
Brad
On May 16, 7:00*am, John Roche-Kelly
wrote: Brad have you turned the logger on in the setup menu? Best wishes JohnR-K Hi John, I found the reason why: in the setup menu for the logger config I changed the logger I.D. from the original (default) BLANK setting to my call sign which is AK. I went thru and check all my logged flights up to when I was having problems and noticed the .igc name had changed so I figured that must be the problem, and it was. Now, the other issue I am dealing with is getting the program to save the changes I make to a custom named profile. For some reason none of the changes seem to hold when I restart the program and select my_profile.prf Cheers, Brad |
Hi Brad, The place to ask these questions is the xcsoar-user mailing list, he https://lists.sourceforge.net/lists/...fo/xcsoar-user |
On May 16, 8:16*pm, wrote:
Hi Brad, The place to ask these questions is the xcsoar-user mailing list, hehttps://lists.sourceforge.net/lists/...fo/xcsoar-user ah, very good...............thanks for the link! Brad |
Similar Threads | ||||
XC-Soar | [email protected] | Soaring | 4 | January 26th 09 04:06 PM |
Get out of the Cold and SOAR! | Mike Schumann | Soaring | 4 | January 22nd 09 06:03 AM |
XC Soar and iPaq 310? | Brad[_2_] | Soaring | 4 | November 19th 08 12:30 PM |
why do you soar? | Mark James Boyd | Soaring | 27 | October 21st 03 07:48 PM |
adrenaline, was why do you soar? | Robert Ehrlich | Soaring | 6 | October 13th 03 09:08 PM |
