2-32 Canopy Needed
Does anyone have a lead on a replacement SGS 2-32 canopy. Ours is going to need to be replace before too much longer.
Thanks |
2-32 Canopy Needed
On Jan 10, 5:53*pm, SoaringNV wrote:
Does anyone have a lead on a replacement SGS 2-32 canopy. *Ours is going to need to be replace before too much longer. Thanks Check K&L first, but I know that the place in LA (http:// www.ceebaileys.com/) is FAA/PMA approved and has molds for the 1-26/2-33. I have seen and installed their 1-26 canopy and it was very well done. Most folks vastly underestimate the work involved in locating and drilling the attach holes, the Cee Baily products are predrilled. I believe Cee Baily has done the 2-32 before, but since this one is moldless and free blown, I have seen some pretty bad aftermarket canopies. At the least, you want to make a few templates to make sure it has the right contour, and you don't end up with not enough headroom. If the countour of your present canopy is off, as is the one on 9851E, you might contact the owners of the "New" 2-32 at Crystal with the original canopy, You could ask them to make a few measurements for you. |
2-32 Canopy Needed
Please email pa12joeataol.com
2-32 Canopy Needed
On Thursday, January 10, 2013 at 6:53:46 PM UTC-7, SoaringNV wrote:
Does anyone have a lead on a replacement SGS 2-32 canopy. Ours is going to need to be replace before too much longer. Thanks Are you still in the market for a 2-32 canopy? Mike 303-817-2097 |
Similar Threads | ||||
Baby Grob Canopy Needed | Alpha One | Soaring | 12 | March 9th 10 01:47 AM |
Needed: LS-4 canopy | [email protected] | Soaring | 1 | May 18th 09 03:21 PM |
SALTO canopy needed | [email protected] | Soaring | 7 | November 21st 08 02:45 AM |
Blanik L-13 Front canopy sheet needed | Roy Bourgeois | Soaring | 1 | June 1st 06 11:31 PM |
DART Canopy needed | Ernie | Soaring | 2 | January 17th 04 03:26 PM |
