Minimum Pilot Weight in a Pilatus B-4
Does anyone know the minimum payload weight for a Pilatus? The max gross is given in the manual, but there seems to be nothing for how light someone can be before adding ballast.
On Monday, October 3, 2016 at 10:43:16 PM UTC-4, wrote:
Does anyone know the minimum payload weight for a Pilatus? The max gross is given in the manual, but there seems to be nothing for how light someone can be before adding ballast. The minimum weight in the pilot's seat should be on the placard but ultimately, you can find out by doing a W&B. The POH should give you the max. aft CG and you can figure out what weight you need in the seat to achieve that position. Uli |
I was close to the limit at 155#. Definitely agree with the advice
to check the W&B. Adding a chute will help. At 03:49 04 October 2016, AS wrote: On Monday, October 3, 2016 at 10:43:16 PM UTC-4, wrote: Does anyone know the minimum payload weight for a Pilatus? The max gross is given in the manual, but there seems to be nothing for how light someone can be before adding ballast. The minimum weight in the pilot's seat should be on the placard but ultimately, you can find out by doing a W&B. The POH should give you the max. aft CG and you can figure out what weight you need in the seat to achieve that position. Uli |
I own #310, and it has a minimum of 53 kilos, max of 97 kilos.
It has been repainted in the past. |
There is also a Pilatus B4 group on Facebook btw.
Similar Threads | ||||
Minimum amount of Maximum pilot weight | Nyal Williams[_2_] | Soaring | 1 | May 22nd 11 10:34 AM |
Airlines Cut Minimum Pilot Experience to 500 hours and Below | Larry Dighera | Piloting | 201 | December 2nd 07 05:53 PM |
Empty/Gross weight Vs. Max. Pilot weight | Flyhighdave | Soaring | 13 | January 14th 04 04:20 AM |
pilot weight and gliding | John Lee | Soaring | 4 | August 31st 03 06:53 PM |
Pilot weight and gliding | JohnH | Soaring | 26 | August 27th 03 11:08 PM |
