Sustainer engine run
Just curious, how long are the guys with solo 2350 sustainer engines running their engines before they depart on XC flights? I have been running the engine for about 30 seconds but I have no idea how long it should to run to be fully lub'ed and kept in good running condition.
2 minutes on every 3rd flight.
19+ years, 1700 flight hours, and 10 engine hours in this period. Bob On Tue, 8 Aug 2017 18:55:11 -0700 (PDT), "Jonathan St. Cloud" wrote: Just curious, how long are the guys with solo 2350 sustainer engines running their engines before they depart on XC flights? I have been running the engine for about 30 seconds but I have no idea how long it should to run to be fully lub'ed and kept in good running condition. --- This email has been checked for viruses by AVG. http://www.avg.com |
At 04:17 09 August 2017, Bob Gibbons wrote:
2 minutes on every 3rd flight. 19+ years, 1700 flight hours, and 10 engine hours in this period. Bob On Tue, 8 Aug 2017 18:55:11 -0700 (PDT), "Jonathan St. Cloud" wrote: Just curious, how long are the guys with solo 2350 sustainer engines running their engines before they depart on XC flights? I have been running the engine for about 30 seconds but I have no idea how long it should to run to be fully lub'ed and kept in good running condition. --- This email has been checked for viruses by AVG. http://www.avg.com We run the motor in our duo for 30seconds to mark the trace. There are some people will accuse you of using it on task if there is no obvious mark. |
At 01:55 09 August 2017, Jonathan St. Cloud wrote:
Just curious, how long are the guys with solo 2350 sustainer engines runnin= g their engines before they depart on XC flights? I have been running the = engine for about 30 seconds but I have no idea how long it should to run to= be fully lub'ed and kept in good running condition. 30seconds. The main reason being to make sure it's probably going to start when I need it! If I forget to do that it concentrates the mind somewhat if I get low later. |
30-60 seconds on EVERY flight before going beyond gliding distance of the airport. Mostly to give you some assurance that it is likely to start if called upon later that day. A short run will also make sure you have the fuel valve open (I always leave my valve open all flight), it will also remove any vapor bubbles in the fuel lines, and if it's cool, it'll warm up the motor a bit which helps it start a bit faster later.
Similar Threads | ||||
Self-launch v Sustainer | Duster | Soaring | 45 | November 9th 16 05:36 PM |
Self Launching/Sustainer engine reserve | [email protected] | Soaring | 2 | July 29th 15 03:31 PM |
ASG-29E vs. JS-1Jet Sustainer | Gerry Simpson | Soaring | 52 | July 8th 15 01:29 PM |
Sustainer engine ignition noise (Solo2350) | Per | Soaring | 8 | January 4th 07 05:56 AM |
DG goes the sustainer option. | Paul | Soaring | 25 | June 4th 04 12:16 AM |
