Sailplane Canopy
Old August 23rd 18, 10:42 PM posted to rec.aviation.soaring
Ross[_3_]
Default Sailplane Canopy
Having owned 2 201 and 2 301 I would really like to know what the difference in the blank canopy is. Surely it cannot be a great deal if anything at all
Fitted a racing canopy to both and I am not sure I could tell you the difference
Here are some pics of that operation and a little more
https://drive.google.com/open?id=0B3...3VfZkdsdFV0cmc
It was a load of work but well worth it in the end
Old August 24th 18, 12:02 AM posted to rec.aviation.soaring
George Haeh
Google for "aircraft canopy makers". There's several.
Old August 24th 18, 12:05 AM posted to rec.aviation.soaring
Craig Funston[_3_]
Beautiful Libelles Ross!
Fitting something like a libelle canopy that doesn't flow into the curvature of the forward fuselage is much more challenging than typical canopies. Lots of small cuts and trial fits.
Cheers,
Craig
Old August 24th 18, 02:15 AM posted to rec.aviation.soaring
Ross I'm not certain what canopy is on you're Libelle. Is that the low profile canopy option Libelle canopy? Is that a canopy for a different type? I want to install the same as you've got. Looks better than the standard Libelle canopy! Yeah if you could tell me the canopy you used and I could get one for less than $1,000 I may go that way and you could give me tips on installation if there are important tricks or particular nuances of such.
Old August 24th 18, 02:19 AM posted to rec.aviation.soaring
Thank You Mr. Whitley and Mr. Leonard for looking into the canopy sourcing matter for me.
Old August 24th 18, 04:18 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Hi Brian,
Yes, the Libelle was offered with two canopy options. I believe they were "Standard" (now referred to as the "racing" canopy) and the "Tall", which is what most have gotten over the years. I agree with you that the "racing" looks a lot "sexier". Fitting in can be an issue for some, but I fit in the FJ-1 (made up of Libelle parts) with its racing canopy, seat back still installed, with a chute on. I am 6'2" tall but have a bit more of my height in my legs, so this gives me a bit more head room, but a tougher fit under the panel for my legs.
I don't know for sure, but I suspect Ross used a Mecaplex canopy, so not an under $1K option.
Steve Leonard
DG 100 canopy? Pete[_9_] Soaring 6 December 5th 17 11:03 PM
Looking for a new canopy for KA-6 [email protected] Soaring 4 November 27th 17 10:27 PM
Canopy Ejection and Canopy Lanyard Casey[_2_] Soaring 6 April 12th 16 05:09 PM
K8 Canopy Jack Wyman Soaring 0 June 9th 04 08:36 PM
SGS 2-32 canopy? Gary Boggs Soaring 0 January 6th 04 11:21 PM
