#11
Mystery holes.
I think you might have something there Frank!
I know 28 years ago as a student pilot, I might have "dented" the runway a few times with my landings! Happy New Year .... Terry N6401F "Frank Olson" wrote in message ... Terry wrote: I suspect the holes are abandoned oil wells from long ago. Nothing left but the damage from bringing up the "substrate" to the surface. Limestone, oil soaked earth etc that no plant can grow in or at least is favorable to the local vegetation. That whole area around Galveston is riddled with those holes. I understand years ago that area had hundreds of oil wells in a few block area. Thats my guess! Terry I disagree. I suspect that the "pilot" at the controls of the UFO that did this was a student and was practicing "touch and go's". :-) |
Mystery holes.
on 12/25/08 9:08 AM Paul kgyy said the following:
On Dec 24, 5:27 pm, Monk wrote: I stumbled across this earlier today. Below is the quote and link to picture. Although I've seen several areas with similar holes, this particular set is right next to Bastrop Bayou, near the bridge where CR 227 crosses over it. Approximate lat/long is N29.094 W95.290. Usually the holes are near a body of water: a river, stream, bayou, canal, etc. And they are always water filled. Any ideas? http://www.texas-flyer.com/LightFlyer/holes.jpg Could be geologic sinkholes? Underlying limestone dissolves in acid- bearing water and caves in underneath? They look too regular to be natural sinkholes to me. I wonder if they're abandoned sulphur mining drill holes. The area is known for extracting sulphur by pumping superheated water down to deposits to melt the mineral, which is then forced to the surface with compressed air. |
Mystery holes.
Rich Ahrens wrote:
on 12/25/08 9:08 AM Paul kgyy said the following: On Dec 24, 5:27 pm, Monk wrote: I stumbled across this earlier today. Below is the quote and link to picture. Although I've seen several areas with similar holes, this particular set is right next to Bastrop Bayou, near the bridge where CR 227 crosses over it. Approximate lat/long is N29.094 W95.290. Usually the holes are near a body of water: a river, stream, bayou, canal, etc. And they are always water filled. Any ideas? http://www.texas-flyer.com/LightFlyer/holes.jpg Could be geologic sinkholes? Underlying limestone dissolves in acid- bearing water and caves in underneath? They look too regular to be natural sinkholes to me. I wonder if they're abandoned sulphur mining drill holes. The area is known for extracting sulphur by pumping superheated water down to deposits to melt the mineral, which is then forced to the surface with compressed air. Swamp Monster Fart Bubbles |
Mystery holes.
On Thu, 25 Dec 2008 14:43:58 -0600, Viperdoc wrote:
Anthony said: Sinkholes, areas where the ground at the surface has collapsed downwards due to underground erosion or subsidence. A true genius in his own mind- so helpful and beneficent. Responded to by a feckin' idiot of less mental head. -- Bear Bottoms Private Attorney General |
Mystery holes.
"Bear Bottoms" wrote in message
... On Thu, 25 Dec 2008 14:43:58 -0600, Viperdoc wrote: Anthony said: Sinkholes, areas where the ground at the surface has collapsed downwards due to underground erosion or subsidence. A true genius in his own mind- so helpful and beneficent. Responded to by a feckin' idiot of less mental head. ....sez the imposter 12yr old kook. |
Mystery holes.
Terry wrote:
I think you might have something there Frank! I know 28 years ago as a student pilot, I might have "dented" the runway a few times with my landings! I was always told it's "good form" to fill in your divots afterwards... :-) Happy New Year .... Terry N6401F Same to you and yours! |
Mystery holes.
"Mike" nospam @ aol.com wrote in message ... | "Bear Bottoms" wrote in message | ... | On Thu, 25 Dec 2008 14:43:58 -0600, Viperdoc wrote: | | Anthony said: | | Sinkholes, areas where the ground at the surface has collapsed downwards | due | to underground erosion or subsidence. | | A true genius in his own mind- so helpful and beneficent. | | Responded to by a feckin' idiot of less mental head. | | ...sez the imposter 12yr old kook. | Sez the 7 year old wanna be kook. |
Similar Threads | ||||
Covering holes | [email protected] | Soaring | 9 | May 2nd 08 05:57 PM |
Tube Fuse Oil Holes | John[_17_] | Home Built | 8 | March 21st 08 12:11 PM |
When Poorboys drill holes ...was: Drilling holes in steel tubing | wright1902glider | Home Built | 4 | November 4th 05 01:19 AM |
Drilling holes in steel tubing | wright1902glider | Home Built | 20 | October 9th 05 03:43 AM |
Filling Holes | AKperson | Owning | 1 | July 20th 05 03:54 PM |
