Here's a question for the trolls and flight simmers
glory be, what can the answer be?
On Jun 25, 10:46 am, alexy wrote: Stealth Pilot wrote: On Wed, 25 Jun 2008 12:43:21 GMT, "Mike" wrote: "Stealth Pilot" wrote in message . .. I know we beat on you guys a lot here but here is a serious question for you to explore. scenario: you are flying along on a bright sunny day with no cloud cover. your wingspan is about 20 ft, fuselage length 14ft and tailplane about 8ft span. your altitude is 4,500ft. you look down below you in the exact opposite direction to the sun. what do you see below you scooting along the ground below you? is it a sharply defined shadow of your aircraft? a fuzzy indistinct shadow of your aeroplane? or what? it is quite distinct and you can pick it from nearly a mile away. ....now pilots dont tell them. these guys are actually quite intelligent but not in' hands on' aviation matters. they should be able to work this out. In the grand scheme of "hands on aviation matters", how many beans are in this hill? I notice that there are no attempts at an answer. Well, you directed the question to flight simmers and trolls. If you want to open it up to non-pilot lurkers, I'll take a guess. Assuming you will reveal the correct answer and explain it. -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
On Wed, 25 Jun 2008 15:05:19 -0400, alexy wrote:
wrote: Well, you directed the question to flight simmers and trolls. If you want to open it up to non-pilot lurkers, I'll take a guess. Assuming you will reveal the correct answer and explain it. glory be, what can the answer be? My guess is that since the plane will subtend a much smaller angle than the sun, there would be no noticeable shadow. My guess is a "halo" around where the shadow would be, caused by diffraction, Since most of the edges tend to be inline with the plane's axis or perpendicular to it, it seems that this halo might be somewhat brighter on those two axes, but I wonder if that would be noticeable. The halo might have a slightly bluish cast, since the red end of the spectrum would get diffracted more, and being over a larger area would be not as bright. So, what's the real answer? sitting on the ground with the sun about 93 million miles away the aircraft casts a sharp shadow on the ground. at 500ft altitude the aircraft is 500ft closer to the sun than the previous 93 million miles, which is next to no change at all, so there will be very little change to the shadow you'd think. but there is. at 500ft the aircraft shadow is a very indistinct blur surrounded by a halo of bright light. at 4,500ft (the original question) the aircraft has no shadow at all but at the sub solar point (were you'd think the shadow should be) there is a distinct bright area tracking along under the aircraft. for thirty years this quietly puzzled me. it is a fact that aircraft at altitude have no shadow. below them tracking along the ground is a bright spot of light. the reference I gave gives details of some original work by Fresnel which proposed that light passing beside a gravitational mass should be bent slightly by the mass and behind the body there should be a bright spot. this seems to me to be the explanation for the absense of the shadow. the mass of the aircraft acts as a gravitational lens and this causes the bright spot. the reason I asked the question was to point out that simulators work on a simplified model of the reality that real pilots are exposed to. people like mxsmanic seem utterly oblivious to the fact that their exposure to the simulator will never give them competent knowledge because all they are exposed to is a simplified model of reality. it is only exposure to the actual reality that will allow you to achieve competent knowledge. if simulators dont get something as simple as the aircraft's shadow right can you trust that anything else they show you is right? Stealth Pilot |
I'm sorry, I didn't see this post until now. One of the
fondest memories of my first solo was seeing my own shadow below. I guess my attention was elsewhere while I had the CFI in the cockpit with me. Lou |
Lou wrote:
I'm sorry, I didn't see this post until now. One of the fondest memories of my first solo was seeing my own shadow below. My strongest memories were how the plane LEPT off the surface with 200 less pounds and more rearward GC, and remembering on downwind that I HAD to land the plane with no reminders or comments from the CFI. My PP CFI was a "master of distraction" type of chatty guy. He would continually yak on about things that had nothing to do with flying. I also noticed how peaceful solo flight was! G |
My PP CFI was a "master of distraction" type of chatty guy. He would continually yak on about things that had nothing to do with flying. I also noticed how peaceful solo flight was! G That's funny, while reading this I was thinking the same thing. My CFI kept talking about things he did over the weekend, what did I do etc. I guess it worked. Lou |
Lou wrote:
My PP CFI was a "master of distraction" type of chatty guy. He would continually yak on about things that had nothing to do with flying. I also noticed how peaceful solo flight was! G That's funny, while reading this I was thinking the same thing. My CFI kept talking about things he did over the weekend, what did I do etc. I guess it worked. It did! All the same stuff non-flying pax talk about that can easily draw you in and away from flying. The quiet on the first solo, without him yakkin' away, was soooooooooooo noticeable! G |
On Jun 29, 9:59*am, Lou wrote:
I'm sorry, I didn't see this post until now. One of the fondest memories of my first solo was seeing my own shadow below. I guess my attention was elsewhere while I had the CFI in the cockpit with me. * * * *Lou I agree. Right up there with my first Flightaware track was seeing my airplane shadow the first time. There are some things that really point out that you are now different than most of the population because you can fly a plane. |
Stealth Pilot wrote: at 4,500ft (the original question) the aircraft has no shadow at all but at the sub solar point (were you'd think the shadow should be) there is a distinct bright area tracking along under the aircraft. for thirty years this quietly puzzled me. it is a fact that aircraft at altitude have no shadow. below them tracking along the ground is a bright spot of light. the reference I gave gives details of some original work by Fresnel which proposed that light passing beside a gravitational mass should be bent slightly by the mass and behind the body there should be a bright spot. this seems to me to be the explanation for the absense of the shadow. the mass of the aircraft acts as a gravitational lens and this causes the bright spot. Poisson spot, Spot of Arago, Keller edge waves. Very much doubt gravitational bending of light is involved. |
On Sun, 29 Jun 2008 08:24:13 -0700, AES wrote:
In article , Stealth Pilot wrote: at 4,500ft (the original question) the aircraft has no shadow at all but at the sub solar point (were you'd think the shadow should be) there is a distinct bright area tracking along under the aircraft. for thirty years this quietly puzzled me. it is a fact that aircraft at altitude have no shadow. below them tracking along the ground is a bright spot of light. the reference I gave gives details of some original work by Fresnel which proposed that light passing beside a gravitational mass should be bent slightly by the mass and behind the body there should be a bright spot. this seems to me to be the explanation for the absense of the shadow. the mass of the aircraft acts as a gravitational lens and this causes the bright spot. Poisson spot, Spot of Arago, Keller edge waves. Very much doubt gravitational bending of light is involved. I looked up explanations and graphics of these effects. the poissons spot demo looks entirely different from what I see. I'm still happy with my explanation. Stealth Pilot |
Similar Threads | ||||
Pilot's Assistant Directory - Free Information Resource for Flight Simmers - Updated | AirToob | Simulators | 0 | July 19th 07 11:10 AM |
(OT) MS Simmers | Dan544 | Piloting | 66 | May 7th 07 10:04 PM |
Slightly O/T for flight simmers. Building my own airport | Andrew Scotland | Simulators | 4 | July 24th 05 10:13 PM |
Check This Out!!! (must have for all flight simmers) | Boeing747 | Simulators | 1 | July 3rd 04 12:43 AM |
Calling Simmers in the Midlands, UK | 'Mort' | Simulators | 0 | March 24th 04 08:16 PM |
