#31
BUFDRVR wrote:
If it's qn excess thrust issue, than that would weight it even further into the "Yes, sure the B-1 can do an Immelman" side. Of all the things the B-47 didn't have, thrust Remember, the B-47 did their immelmans from high altitude (and entered from a dive obviously), the Afghanistan Bone would be entering from straight and level, thus it becomes an excess thrust issue. See below. Well, fly around the pattern trailing a parachute is one... Tobogganing behind an overstressed KC-97 would be another. Cruising around, fully loaded (albeit a smaller load than a BUFF or Bone) at 40K+ and .90 mach. Nope. B-47E SAC: Max. Spd, 606 mph (M0.84) @ 16,300 ft.; 557 mph (M0.842) @ 38,550 ft.; Max. cr. spd., 495 mph (M0.75) @ 38,550 ft.; Svc. Ceiling 40,500 ft. Doing an immelman at high altitude (not possible for a BUFF...maybe for a Bone, but not from 30K+). The Immelmanns were done from the deck while making LABS tosses, starting in 1957. They went down there for the same reasons the B-52s did: defenses had driven them from high altitude to low. There were 6 B-47 crashes in the spring of 1958 brought on by fatigue failures due to these and pop-up maneuvers, which is why Project Milk Bottle was instituted, to replace the wing milk bottle connecting pin. Guy |
#32
Guy Alcala wrote in message ...
BUFDRVR wrote: SNIP Some of the B47 wing failures were due to high speed low altitude flying in turbulence. 420 KIAS down around Avon Park Range (FL) in the summer can get real bumpy. As I remember McCoy AFB (Orlando Intl now) got its name from a SAC brigadier who bought it, along with his crew, as his B47 lost a wing in a LABS maneuver. FWIW if the Bone engines are anything like the J79 at 700 KIAS they're putting out maybe 25% more thrust than under static conditions. I have seen the J79's fuel flow rise from about 8500 pph static to over 12000 pph going from 0 KIAS (brakes locked) to 600 KIAS at 500 feet off the end of the runway. Even so, with the kinetic energy of 700 KIAS that elephant should be able to leap tall buildings. Walt BJ |
#33
at 40K+ and .90 mach. Nope. B-47E SAC: Max. Spd, 606 mph (M0.84) @ 16,300 ft.; 557 mph (M0.842) @ 38,550 ft.; Max. cr. spd Hmmm, I stand corrected, I thought the -47 was faster than a BUFF at altitude...apparently not. The Immelmanns were done from the deck while making LABS tosses, starting in 1957. Well, I've seen a picture (I'll try to find it) of a B-47 nearly inverted and while exact altitude is difficult to determine, there's no visable terrain in the shot....which has always left me the impression they were at least 20K. BUFDRVR "Stay on the bomb run boys, I'm gonna get those bomb doors open if it harelips everyone on Bear Creek" |
#34
#35
The A-6 loft profile was 4 g's from on the deck as fast as you could go so call
it 450 indicated at the beginning of the pull. we would top out at about 8K. So even with the B-47's 2-3 g pull I doubt that they topped out much above 10-12K. When the manuver is viewed from the side from the ground the manuver looks like an egg with the narrow corner at the top hence the fighter reference to the combat egg. Lower air speed = smaller radius of turn. The Immelmanns were done from the deck while making LABS tosses, starting in 1957. Well, I've seen a picture (I'll try to find it) of a B-47 nearly inverted and while exact altitude is difficult to determine, there's no visable terrain in the shot....which has always left me the impression they were at least 20K. Hmm. It could be that they were topping out that high. IIRC, when they were doing the LABS drops, they were entering the pullup at aound 420 KIAS, and pulling up at 2 - 2 1/2 Gs. It's still impressive, nonetheless. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
Similar Threads | ||||
Pilot who bombed Canadians in Afghanistan to sue US air force . | Otis Willie | Military Aviation | 0 | July 8th 04 09:38 PM |
Airmen deliver 35,000 helmets to Afghanistan | Otis Willie | Military Aviation | 0 | June 30th 04 10:51 PM |
[OT] Gullible Bush was suckered over bio warfare trucks | No SPAM | Military Aviation | 1 | March 29th 04 12:04 PM |
"Priceless" in Afghanistan | BUFDRVR | Military Aviation | 15 | February 28th 04 04:17 PM |
Priceless in Afganistan | breyfogle | Military Aviation | 18 | February 24th 04 05:54 AM |
