#34
Ok, here's the deal:
2035 TT A&E - Sundowner, had to be from the 1970's so it is at least 25 years old, if not 30+. Engines have two TBO's. The hours we are all familiar with and a calendar time, which for the Lycomings ( all Sundowners are O320 or O360 powered ) is 12 years or 2000 hours. You may, as a part 91 operator, exceed TBO, as it is only a recommended number, not a mandatory life limit. But your Sundowner is a runout by hours and years. The 4k thing isn't relevant. If I were selling the plane, I wouldn't buy you a new overhaul either. On the other hand, I'd be realistic about the actual market value of the aircraft considering its condition. There are two evaluators you should consider: AOPA's VRef and Trade-a-plane's evaluator. The TAP is a little better if you are a buyer. AOPA's is better for owner's buying insurance or trying to sell. Sundowners can be hard to sell, a friend of mine had a tough time selling his. So how much is this plane worth to YOU? So here's what you need to consider in your decision: How much is this plane worth to you? Consider that it is likely to need an engine overhaul soon, perhaps right away. I just went through that process on the plane I bought last summer. Checked it out nine ways to sunday, and it spit up a bearing 50 hours later. So stuff happens. It was not quite a run-out, but it was priced according to its hours. Overhauls are expensive. You'll also find a whole lot of other piddly crap to fix while the engine is off, like the mount, the Lord mounts, the exhaust, the oil cooler, the hoses, alternator, a few wires, a cracked baffle or two, new baffle seals, a new vacuum pump... A carb'd O360 with new cylinders will cost you about $15k altogether, just for the motor in a first class shop. Then you got labor to put it back on, and all the above mentioned stuff. Overhauling an exhaust with 4 stacks and mufflers and shrouds will cost you about $800, mount overhaul will run about $1k, 4 new lord mounts are about $300. New mixture and throttle cables will run you about $500 a baffle or two will probably be cracked and need replacing with a new "famous Beech quality" part from Raytheon. Ask me how I know all of this... Depending on how committed you are after the process (ie, how much money you spend), you'll have a nice shiny new reliable motor in your plane and a bunch of shiny new reliable parts to go with it. So what you do is figure out how much you want to put into this deal and work from there. If you want a plane to keep for a while, then shop for an overhaul with all the trimmings, subtract that from what you think the plane is worth with 0-smoh, offer that much to the owner, see if you get anywhere. Keep in mind that every plane worth having, someone has probably put more than it is worth into it. If you are looking for a time-builder, shop for an ugly-duckling with a low-time, good running motor and sufficient avionics to get your IFR and commercial in and a few hundred hours of x-country time and no further investment beyond maintenance. My advice, since you are a student, is just to rent until you get your private pilot license. Owning is a hobby all of its own and a burden you probably don't want distracting you from training while you are trying to finish off your initial training. In article , "DHead" wrote: Hi group. I am interested in buying a Sundowner with 2035 TT E&A. The owner (actually the broker) offered to allow $5K off the asking price to have the engine O/H'd. I am a student pilot and very much want this particular airplane, but I don't think that $5K off a $14K O/H is reasonable. The avionics are ok, but could be improved on. My biggest concern at this point is the engine time. Any opinions on what is fair to me and the seller concerning allowances for the engine O/H? Thanks in advance. Gary Future pilot without a plane |
Similar Threads | ||||
Mooney Engine Problem in Flight - Advise | Paul Smedshammer | Owning | 17 | December 21st 04 06:39 AM |
Mooney Engine Problems in Flight | Paul Smedshammer | Piloting | 45 | December 18th 04 09:40 AM |
ROP masking of engine problems | Roger Long | Owning | 4 | September 27th 04 07:36 PM |
Diesel engine | Bryan | Home Built | 41 | May 1st 04 07:23 PM |
Objective Engine Discussion | Rick Maddy | Home Built | 26 | October 14th 03 04:46 AM |
