Any prohibition on more than one splice on a member?
Old September 10th 07, 12:53 AM posted to rec.aviation.owning
Michael Horowitz
Default Any prohibition on more than one splice on a member?
I removed a questionable external splice on a Taylorcraft landing
gear. The splice was on the streamlined strut. Unfortunately,
removing the splice didn't allow enough original tubing at the lower
end to apply an external sleeve. So I figured I'd install a splice
using an internal sleeve and give myself enough strut to then use an
external splice higher up the strut.
Is there a prohibition on putting more than one splice on a member? -
Mike
Old September 10th 07, 02:17 AM posted to rec.aviation.owning
Mike Noel
Any splice can introduce new stresses in a load bearing member. I would
leave a repair like this to someone qualified to do the job. There is too
much to loose if the repair fails.
Best Regards,
Mike
http://photoshow.comcast.net/mikenoel
A frog in a well does not know the great sea.
"Michael Horowitz" wrote in message
Mike
Old September 10th 07, 01:29 PM posted to rec.aviation.owning
Stealth Pilot[_2_]
On Sun, 09 Sep 2007 19:53:36 -0400, Michael Horowitz
Mike
buy a serviceable spare part.
Officially a Member! Douglas Paterson Owning 17 September 12th 07 05:27 AM
transparancy/member information 5-BG Soaring 14 October 20th 06 10:01 PM
SSA Member Area [email protected] Soaring 4 September 5th 06 12:49 AM
Pegaus AD(s) - New Member to the Group Steve Swann Soaring 0 April 26th 05 04:11 PM
Need suggestions for clean butt splice for electrical wires. Bart D. Hull Home Built 9 January 30th 04 04:28 AM
