#11
GAMIjectors
wrote in message ... On Fri, 7 Sep 2007 11:16:54 -0600, "Jon Woellhaf" wrote: "Newps" wrote ... This years compression check...every cylinder 80/80. How is that possible? real simple with a wet top end and tight valves. a clapped-out R-985 will read 80/80 right up to the point when it reads 0/80 instead. Kinda hard to have a wet top end in a Continental 520/550, isn't it? |
GAMIjectors
On Fri, 7 Sep 2007 19:12:45 -0700, "Matt Barrow"
wrote: wrote in message .. . On Fri, 7 Sep 2007 11:16:54 -0600, "Jon Woellhaf" wrote: "Newps" wrote ... This years compression check...every cylinder 80/80. How is that possible? real simple with a wet top end and tight valves. a clapped-out R-985 will read 80/80 right up to the point when it reads 0/80 instead. Kinda hard to have a wet top end in a Continental 520/550, isn't it? uh, no. |
GAMIjectors
Scott Skylane wrote: Newps wrote: Jon Woellhaf wrote: "Newps" wrote ... This years compression check...every cylinder 80/80. How is that possible? My superior engine management techniques. If you plug the compression tester into the cylinder, but forget to open the shutoff valve, both gauges read "80". Only one would on the ones I've used. |
GAMIjectors
wrote in message ... On Fri, 7 Sep 2007 19:12:45 -0700, "Matt Barrow" wrote: wrote in message . .. On Fri, 7 Sep 2007 11:16:54 -0600, "Jon Woellhaf" wrote: "Newps" wrote ... This years compression check...every cylinder 80/80. How is that possible? real simple with a wet top end and tight valves. a clapped-out R-985 will read 80/80 right up to the point when it reads 0/80 instead. Kinda hard to have a wet top end in a Continental 520/550, isn't it? uh, no. Okay...so I'm misunderstanding a wet top end. Still, you inferred the accusation that Newps was faking his compression levels, so put up or shut up. |
GAMIjectors
On Sep 7, 7:54 pm, wrote:
On Fri, 7 Sep 2007 11:16:54 -0600, "Jon Woellhaf" wrote: "Newps" wrote ... This years compression check...every cylinder 80/80. How is that possible? real simple with a wet top end and tight valves. a clapped-out R-985 will read 80/80 right up to the point when it reads 0/80 instead. TC Never yet have I seen any 80/80 cylinder, and I do this full time. Most of those gauges are off a little, and if they're not calibrated they're not accurate. The highest I ever see is 79/80. The ring gaps alone will ensure some readable leakage. If the gauges are accurate and they read 80/80, then the orifice inside the tester is too large and he's not getting enough pressure drop. There are two sizes of those things, for small and large engines. Your mechanic might be using the wrong one. Dan |
GAMIjectors
... This years compression check...every cylinder 80/80. How is that possible? real simple with a wet top end and tight valves. a clapped-out R-985 will read 80/80 right up to the point when it reads 0/80 instead. TC Never yet have I seen any 80/80 cylinder, and I do this full time. Most of those gauges are off a little, and if they're not calibrated they're not accurate. The highest I ever see is 79/80. The ring gaps alone will ensure some readable leakage. If the gauges are accurate and they read 80/80, then the orifice inside the tester is too large and he's not getting enough pressure drop. There are two sizes of those things, for small and large engines. Your mechanic might be using the wrong one. Dan It is not unreasonable to expect the dime store quality gauges used in these testers to be off 1-2% or more. So, a reading of 80/80 seems quite possible. The "true" pressures may be a bit different. I would not get crazy over the small error/difference in one reading. Trends seem to matter more as a measure of a cylinder's health. Mike |
GAMIjectors
Matt Barrow wrote: real simple with a wet top end and tight valves. a clapped-out R-985 will read 80/80 right up to the point when it reads 0/80 instead. Kinda hard to have a wet top end in a Continental 520/550, isn't it? uh, no. Okay...so I'm misunderstanding a wet top end. Still, you inferred the accusation that Newps was faking his compression levels, so put up or shut up. I'm assuming a wet top end is an engine tested that just got done flying. My engine was cold, the mechanic towed it over to his side of the T hangar building that morning so all cylinders were 60 degrees F |
GAMIjectors
On Thu, 6 Sep 2007 15:11:55 -0500, "Dan Luke"
wrote: Has anybody here put GAMIjectors on their LYC. TIO-540? If so, how did you like them? I have them on my Lyc IO-360. I am currently on my fourth iteration. Each time I did a lean test, it was not adequate, so I emailed the results to GAMI who then sent one to three new injectors to try. My last test resulted in three cylinders peaking close together with #2 off, so that was just replaced. I haven't yet checked the lean test with my new #2 but I really hope it does the trick. This has been a bit frustrating and has taken almost a year. Having said that I am happy with the service from GAMI, and I still believe they are a good idea. randall g =%^) PPASEL+Night 1974 Cardinal RG http://www.telemark.net/randallg Lots of aerial photographs of British Columbia at: http://www.telemark.net/randallg/photos.htm Vancouver's famous Kat Kam: http://www.katkam.ca |
GAMIjectors
"randall g" wrote: Has anybody here put GAMIjectors on their LYC. TIO-540? If so, how did you like them? I have them on my Lyc IO-360. I am currently on my fourth iteration. Each time I did a lean test, it was not adequate, so I emailed the results to GAMI who then sent one to three new injectors to try. My last test resulted in three cylinders peaking close together with #2 off, so that was just replaced. I haven't yet checked the lean test with my new #2 but I really hope it does the trick. This has been a bit frustrating and has taken almost a year. Ouch. I have 50% more cylinders, so it ought to take 18 mos. to get mine right. Having said that I am happy with the service from GAMI, and I still believe they are a good idea. Thanks. -- Dan T-182T at BFM |
GAMIjectors
"Newps" wrote in message . .. Matt Barrow wrote: real simple with a wet top end and tight valves. a clapped-out R-985 will read 80/80 right up to the point when it reads 0/80 instead. Kinda hard to have a wet top end in a Continental 520/550, isn't it? uh, no. Okay...so I'm misunderstanding a wet top end. Still, you inferred the accusation that Newps was faking his compression levels, so put up or shut up. I'm assuming a wet top end is an engine tested that just got done flying. My engine was cold, the mechanic towed it over to his side of the T hangar building that morning so all cylinders were 60 degrees F |
