15m task cancelled in WGC
Old January 14th 17, 05:57 AM posted to rec.aviation.soaring
Dan Daly[_2_]
Default 15m task cancelled in WGC
While most were on final leg. Hope it isn't same reason as in WGC Uvalde.
Old January 14th 17, 06:38 AM posted to rec.aviation.soaring
Tom Kelley #711
@WGC2017Benalla
Following a midair collision between two 15M Class gliders, both pilots bailed out and both are confirmed safe on the ground. IDs to follow.
Old January 14th 17, 07:55 AM posted to rec.aviation.soaring
Chris Wedgwood[_2_]
"Due to a midair collision while on task between two gliders in the 15 M Class, the day for 15 M has been cancelled. The pilots involved are Stehpen O'Donnell from Australia and Michale Eisele from Germany. The accident is being investigated and we will issue more information as soon as we are able to."
Old January 14th 17, 08:41 AM posted to rec.aviation.soaring
Bruce Hoult
What does cancelling the task achieve at that point? Horse. Stable.
It's not like there's a race track that needs to be cleaned up, or any danger of someone else crashing into the wrecks on the ground while they are being recovered.
Old January 14th 17, 08:57 AM posted to rec.aviation.soaring
Chris Wedgwood[_2_]
In the chat of the live tracking it was said that some other pilots landed to assist. That's a great spirit, and should not be penalised by losing points.
Old January 14th 17, 09:40 AM posted to rec.aviation.soaring
krasw
I have witnessed a fatal mid-air in competition, right in front of my eyes. Couple of observations of pilot behavior:
1) I did not even once think about continuing the task, instead I stayed over accident site to assist search and co-ordinate rescue with ATC.
2) Paradoxically, most of pilots (there was a huge gaggle, as usual) did not even think about abandoning task and head back home, even after seeing or hearing what happened. They flew the task after accident. It was fruitless of course, day is always cancelled.
In that sense, it is very wise for organisation to cancel the day right after hearing about mid-air and inform team captains immediately. It will be cancelled no matter what, even one pilot have made one extra turn because of mid-air. You have ZERO arguments against protest made on basis that pilot stayed at accident site to assist.
But as I said in other thread, competitions and mid-airs is routine we live with. It is quite simply unbearable.
Old January 14th 17, 10:56 AM posted to rec.aviation.soaring
Jock Proudfoot
Old January 14th 17, 04:24 PM posted to rec.aviation.soaring
I remember a contest day canceled after a fatal accident on the Whites (Bishop, Ca) Chuck Fisher landed and hiked up there to no avail.........seem to remember a contestant protesting all the way to the SSA board and won the protest!
Gary, do I have this right?
JJ
Old January 15th 17, 03:05 PM posted to rec.aviation.soaring
Tim Taylor
I just noticed that Stephen ODonnell had posted cockpit video to the web. I wonder if the video from day four were able to be recovered. It would be interesting to see the video coupled with the flight recorder data.
Old January 15th 17, 06:01 PM posted to rec.aviation.soaring
Jim White[_3_]
be
When you start directing a video you stop being pilot. QED.
Day cancelled at Mifflin (again) Frank Paynter[_2_] Soaring 0 May 24th 11 07:36 PM
Day cancelled at Mifflin Frank Paynter[_2_] Soaring 0 May 23rd 11 05:30 PM
F/A-22's getting cancelled? p6pentiumpro Military Aviation 0 April 16th 04 09:32 AM
Comanche cancelled? Jim Caldwell Military Aviation 1 March 7th 04 01:17 PM
Comanche cancelled fffasdef Rotorcraft 2 February 24th 04 03:22 AM
