Time for certificate issuance?
I passed my IA checkride on April 17th, and still haven't received my
newfangled plastic certificate. The FAA airmen database lists the rating, so I know they're aware of it. The DE gave me a temporary certificate which expires in less than a month, what should I do assuming it doesn't come soon? What's the usual turnaround time for such things? Thanks, Jeremy |
if it's in the data base.. I'm betting it will be in your mailbox in less
than a week.. more likely before you read this post.. the turn around this spring has been running about 90 days BT "Jeremy Lew" wrote in message ... I passed my IA checkride on April 17th, and still haven't received my newfangled plastic certificate. The FAA airmen database lists the rating, so I know they're aware of it. The DE gave me a temporary certificate which expires in less than a month, what should I do assuming it doesn't come soon? What's the usual turnaround time for such things? Thanks, Jeremy |
"Jeremy Lew" wrote in message ... I passed my IA checkride on April 17th, and still haven't received my newfangled plastic certificate. The FAA airmen database lists the rating, so I know they're aware of it. The DE gave me a temporary certificate which expires in less than a month, what should I do assuming it doesn't come soon? What's the usual turnaround time for such things? Thanks, Jeremy Nothing, it will be with you soon, http://registry.faa.gov/airmen.asp |
CB wrote:
"Jeremy Lew" wrote in message ... I passed my IA checkride on April 17th, and still haven't received my newfangled plastic certificate. The FAA airmen database lists the rating, so I know they're aware of it. The DE gave me a temporary certificate which expires in less than a month, what should I do assuming it doesn't come soon? What's the usual turnaround time for such things? Thanks, Jeremy Nothing, it will be with you soon, http://registry.faa.gov/airmen.asp If not, drop in on your local FSDO. They'll write another temporary certificate for you. |
Jeremy Lew wrote:
I passed my IA checkride on April 17th, and still haven't received my newfangled plastic certificate. The FAA airmen database lists the rating, so I know they're aware of it. The DE gave me a temporary certificate which expires in less than a month, what should I do assuming it doesn't come soon? What's the usual turnaround time for such things? According to the registrar webpage, they are currently processing certificates with an approximate issue date of April 25th, 2004 . |
On Sun, 18 Jul 2004 21:42:35 -0400, "Jeremy Lew"
wrote: I passed my IA checkride on April 17th, and still haven't received my newfangled plastic certificate. The FAA airmen database lists the rating, so I know they're aware of it. The DE gave me a temporary certificate which expires in less than a month, what should I do assuming it doesn't come soon? What's the usual turnaround time for such things? Thanks, Jeremy My CFI was renewed on April 13th. I just got it yesterday. Yours should be arriving shortly. If you don't get it, go to your FSDO before the temp expires and you'll get another temp. z |
Similar Threads | ||||
Sport Pilot cuts off special issuance at the knees | Juan~--~Jimenez | Home Built | 40 | August 10th 04 01:19 PM |
My First Time In Severe Turbulence (Long) | David B. Cole | Instrument Flight Rules | 6 | March 10th 04 10:21 PM |
Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 05:54 PM |
Alodine Max Setup time | JDupre5762 | Home Built | 1 | September 6th 03 04:40 PM |
It's that time of year again. | Capt. Doug | Home Built | 19 | September 3rd 03 10:53 PM |
