Does glide ratio change with altitude?
Old September 25th 07, 04:58 AM posted to rec.aviation.ifr,rec.aviation.piloting
Andrew Sarangan
Default Does glide ratio change with altitude?
On Sep 19, 10:43 am, "Jim Carter" wrote:
During a recent discussion about calculating glide ratio, I began to wonder
what the effects of pressure altitude were on the glide ratio of an
aircraft. Since air is 50% as dense at FL180 as at sea level, would the
glide ratio increase (glide further) as altitude decreases? AND if there is
a difference in glide ratio as altitude changes, then what values do most
manufacturers use when they publish their numbers (if they do)?
Oh yeah, I do understand that glide ratio changes to 0:0 upon impact, so the
wags can skip that part of the reply...
Jim Carter
Rogers, Arkansas
This is a very good question. As others have mentioned, max (L/D) and
best glide IAS remain the same regardless of altitude. But that does
not immediately lead to the conclusion that glide ratio also remains
constant. L/D and best glide speed is about indicated airspeeds. At
higher altitudes, the best glide speed (IAS) wll result in a higher
true airspeed. So one might be tempted to conclude that the airplane
may be able to glide father, which is why I suspect you asked the
question in the first place.
It is not sufficient to argue that L/D remains constant, but you also
have to show that L/D is equal to the glide ratio. Glide ratio is the
physical horizontal distance traveled over still air for a unit
vertical altitude lost. Therefore, it is the ratio between the true
airspeed and the true vertical speed (TVS). I am sure there are many
ways to do this, but I find the energy argument the most intuitive.
Consider the power lost to drag, which is (D*TAS). This should be
equal to the rate of energy given up by the airplane due to its
descent. The rate of energy lost due to the descent is W*TVS, where W
is the weight of the airplane. We also know that W=L under
unaccelarated flight. Therefore, D*TAS = L*TVS and we can TAS/TVS =
glide ratio = L/D.
This might be obvious to some, but I had to do this step by step in
order to convince myself that L/D is indeed equal to the glide ratio.
Pehaps you might find it useful.
Old September 25th 07, 12:04 PM posted to rec.aviation.ifr
Adhominem
Jim Carter wrote:
*nitpick with finer granularity*
...and if lift is linearly related to air density and drag is linearly
related to air density, then aren't lift and drag in a linear relationship
to each other?
Well, yes. Anything else wouldn't make much sense, would it? Argh. Must've
forgotten to take my mediaction or s/th.
Ad.
The mail address works, but please notify me via usenet of any mail you send
to it, as it has a retention period of just a few hours.
trivia: highest glide ratio [email protected] Soaring 10 August 4th 06 09:47 PM
So you think you have a low glide ratio! COLIN LAMB Soaring 30 January 12th 06 02:47 PM
question on glide ratio functions in Garmin 96, 96C, 196 GPS Steve S Soaring 1 January 10th 06 07:43 PM
GPS glide ratio calculations james Soaring 0 May 4th 04 09:00 PM
GPS glide ratio calculations Jason Armistead Soaring 16 September 12th 03 04:50 AM
