Ka6 CR fuselage dolly
Old February 13th 17, 08:14 PM posted to rec.aviation.soaring
Default Ka6 CR fuselage dolly
I would like to build a fuselage support dolly for my Ka6 CR does anybody have pictures or plans of one they can share?
Many thanks
Geoff
Old February 14th 17, 12:33 AM posted to rec.aviation.soaring
Many thanks
Geoff
What materials do you plan on using? I have owned two Ka-6cr's. Both were welded square tube steel frames with Saddles of canvas. I think that in my redo of this second one I will try for a fabric lined fiberglass saddle with a steel structure. Start with the trailer and design backwards...keep your critical dimensions at hand, use quality wheels and hardware, provide ample support to the fuselage, keep the ships wheel in mind as well as the cg hook if it is there.
Lining fuselage dolly Colin Roney Soaring 0 April 26th 14 10:19 AM
Lining fuselage dolly Colin Roney Soaring 8 April 25th 14 02:44 AM
Fuselage dolly with over center jack - looking for picture Tim Taylor Soaring 4 July 17th 12 03:21 AM
fuselage dolly caster Brad[_2_] Soaring 9 September 10th 11 02:48 AM
ASK-21 fuselage dolly bildan Soaring 8 August 1st 10 05:43 PM
