Aileron inboard edge sealing
Old March 10th 16, 03:23 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Default Aileron inboard edge sealing
Interesting to note, the JS-1 and Ventus 2 both have fences on inboard flap, fuselage fairing.
Old March 10th 16, 04:49 PM posted to rec.aviation.soaring
While I agree Fences dont add much and can be a pain practicaly, there is benefit in closing up the gaps between the edges of the ailerons and the wing. Some birds have pretty big gaps on the sides of the ailerons which make for drag. On my 1-26, i closed these side gaps thus making the wing trailing edge entirely uniform. While theres not much one can do to increase the performance of the 1-26 wing (non laminar airfoil) I experienced a wonderfull gain in aileron effectiveness. I performed the same procedure on my pilatus B4 years ago. On that bird I did get a noticable gain in performance.
Dan
Old March 10th 16, 05:28 PM posted to rec.aviation.soaring
Dan
Manuals for many glass ships have a specified minimum gap, commonly 1.5mm, between the ends of control surfaces and adjoining parts. Care should be taken to comply with original intent.
FWIW
UH
Old March 10th 16, 05:35 PM posted to rec.aviation.soaring
JS1s aren't fitted with flaperon fences. There is reference to them on the website but they don't fit them to production aircraft as standard - and weren't offered to me as an option.
Old March 10th 16, 11:41 PM posted to rec.aviation.soaring
My end sileron gap seals are made of closed cell foam. They clise the gap virtualy completely and due to being soft foam, has no potential to jam whatsoever, if for some reason they swelled, a single flick of the ailerons would mash them off, its a no brainer.
ASW-20A Left Wing or Inboard Wing Skin Needed Coucked Soaring 0 August 29th 10 02:43 PM
[01/13] - 02 Inboard Starboard Engines.JPG (1/1) Part 2 Waldo.Pepper[_2_] Aviation Photos 0 September 10th 08 11:22 PM
GPS-NAV security sealing Sam Discusflyer[_2_] Soaring 31 August 29th 08 02:28 AM
Sealing an ASW 28 canopy Bob Caldwell Soaring 13 August 10th 05 09:59 PM
Libelle Gap Sealing Owain Walters Soaring 4 April 11th 04 07:13 PM
