Grob 103 front pedal adjustment cable
Old June 20th 13, 05:43 PM posted to rec.aviation.soaring
Bob McKellar
Default Grob 103 front pedal adjustment cable
The cable that allows adjustment of the front pedals in our club 103 Twin II
Acro has broken off at the panel, making moving the pedals awkward.
Where should we be looking for such a specific repair item?
Thanks!
Bob
Old June 20th 13, 08:09 PM posted to rec.aviation.soaring
contact Rudolf
Thanks!
Bob
Old June 22nd 13, 03:30 AM posted to rec.aviation.soaring
Bill T
The US Grob rep is now at Moriarty. Roger Mudd.
Is it the "cable"? Or is it the stiff rod that pokes through the panel with the knob?
The cable should be a standard aircraft cable.
The rod may need to be ordered or suitably substituted and accepted by an IA or DAR.
BillT
Old June 22nd 13, 03:03 PM posted to rec.aviation.soaring
That's ROBERT Mudd. Roger is the one on TV.
Old June 24th 13, 11:21 PM posted to rec.aviation.soaring
This just happened to my club's Twin II Acro as well! Lindner has the part fortunately.
Good thing they do have it as it consists of a solid wire with swaged threaded end fittings riding in a nylon tube unlike the simple cable used by most gliders which would be easy to make! Typical Grob engineering - if someone else has come up with a simple, efficient, inexpensive, reliable way of doing something and it has become almost universal you can rely on them to devise a unique oddball solution to the same problem. I've never got over seeing how the main gear mechanism on our Twin Astir works!
rudder pedal springs Dick[_1_] Home Built 6 May 20th 08 07:23 PM
VNAV placard in DA-40, and pedal adjustment? Roy Smith Owning 4 January 14th 07 04:23 AM
Need Grob 103 Twin II left front rudder pedal Mike McCarron Soaring 1 May 15th 06 02:16 PM
Help, Need Complete Front Canopy for Grob 103 Carl Buehler Soaring 0 December 28th 03 02:15 AM
ASA OnTop 8 Pedal Problem Kevin Instrument Flight Rules 1 August 21st 03 05:42 PM
