Escaping glider on the ground with stuck canopy?
Old May 19th 19, 11:21 AM posted to rec.aviation.soaring
Mike the Strike
Default Escaping glider on the ground with stuck canopy?
The manual for a glider I recently flew for the first time states that if the canopy releases fail the pilot should kick out the Plexiglas.
Seeing how often the canopies of club gliders get broken, I suspect breaking out will be easier than you expect.
Mike
Old May 19th 19, 03:22 PM posted to rec.aviation.soaring
Dan Marotta
Of all the single seaters I've flown, I doubt I could get my feet out
from under the panel to do any kicking.Â* I like the suggestion to keep a
baseball cap with a button on top in the glider.Â* If the canopy gets
stuck, simply change hats and, viola!
Mike
Dan, 5J
Old May 19th 19, 03:53 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
I've never worn a flying hat with button on top, but I hear it can be
painful, so maybe fitting a thickish leather or rubber disk under the
button would be a wise precaution.
Being a Libelle driver, I don't expect my canopy would ever fail to
release but suspect I would not enjoy flipping over.
Martin | martin at
Gregorie | gregorie dot org
Old May 19th 19, 04:55 PM posted to rec.aviation.soaring
Nick Kennedy[_3_]
My take away from this tread is to check and see if your emergency release works.
Next time I've got a couple of savvy strong guys I'm going to stage them to catch my canopy and pull the release and see if it works with me in the plane, then clean and lube the emergency release system. I've had my canopy off several time over the years but never with it closed with the rear pins engaged.
Old May 19th 19, 06:48 PM posted to rec.aviation.soaring
Closest I know of....a certain VA fall site......close to airport.....crashed ASW in trees, many saw lost sailplane.....fuselage was upside down, nose between rocks....skinney pilot, broken canopy, side fuselage structure kept cockpit from crushing....pilot wiggled out and was found by local PooPoo walking off mountain......
Decades ago, a husband/wife team (from our club) gave me and Hank (the real "UH") a short/stout Spyderco pocket knife "just in case".....never needed it, always with me, one hand operation if need be......glad I have it, never hope to need it.....if I think I am going to die, dang straight I will try to waste a canopy....cost is an afterthought.......
Old May 19th 19, 07:42 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Isn't it supported to come off at each annual?
Old May 21st 19, 04:01 AM posted to rec.aviation.soaring
rj
Martin | martin at
Do any of you pilots remember the German army helmets from WW I ?
Do you think that maybe this is what we need ?
  #28
Old May 21st 19, 04:06 AM posted to rec.aviation.soaring
rj
Martin | martin at
The ones with the small spike on the top.
Anyone Ground-Launched a Russia Glider? [email protected] Soaring 15 September 2nd 17 12:06 AM
Where to get a glider canopy in the US Bob Kuykendall Soaring 0 September 4th 08 01:16 AM
Stuck Canopy David Hartung Aviation Photos 2 June 21st 07 05:08 AM
Glider Ground School - Eastern PA RL Soaring 0 December 29th 06 02:19 AM
Glider ground school syllabus [email protected] Soaring 8 November 17th 06 01:50 PM
