Sale today on 12 Volt flexible solar panel
Old November 25th 16, 11:10 PM posted to rec.aviation.soaring
Soartech
Default Sale today on 12 Volt flexible solar panel
Glue on your tail boom and never charge your battery again.
https://www.solarblvd.com/product_in...oducts_id=3082
Old November 25th 16, 11:30 PM posted to rec.aviation.soaring
Andrzej Kobus
I would not do this. The temperature that will be generated under the panel is going to be very high, potentially weakening the structure. Those who glued flexible panels on top of their RVs know what I am talking about. I have seen melted flexible panels.
Old November 26th 16, 03:29 AM posted to rec.aviation.soaring
2G
This panel would be too large to put on a tail boom anyway (despite the quoted dimensions of 46x21mm!). They also imply that you can't bend this thing in an extreme way. On the other hand, the $/W is very good if you can use it in some non-aviation application.
Tom
Old November 26th 16, 03:58 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Soartech wrote on 11/25/2016 3:10 PM:
At 21" x 46" x 0.125", it's too big and probably too heavy. We need
smaller panels to replace the no-longer-available STrobls.
email me)
- "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm
http://soaringsafety.org/prevention/...anes-2014A.pdf
Old November 26th 16, 09:25 AM posted to rec.aviation.soaring
Tango Whisky
Closest I found was www.lemo-solar.de
Old November 26th 16, 01:39 PM posted to rec.aviation.soaring
krasw
Why bother with solar panels when you can buy light weight lithium batteries with enough juice for anything you can imagine? Solar panels are from age of lead batteries.
Old November 26th 16, 03:15 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Not exactly. I know a guy who has a radio, transponder, Butterfly vario, LX9070, S80, Flarm, V3 vario and a strobe built into the vertical fin, that can either act as a strobe or only strobe with a Flarm alert. All that stuff takes about four hours to go through one lithium battery with two factory installed solar panels topping up the battery. Good thing he has two and possibly three batteries (if he is not going to use the engine).
Old November 26th 16, 03:43 PM posted to rec.aviation.soaring
Tango Whisky
Le samedi 26 novembre 2016 14:39:58 UTC+1, krasw a écritÂ*:
Because you might have an engine in the back, and need all that lead in the nose?
Old November 26th 16, 10:26 PM posted to rec.aviation.soaring
2G
Besides effectively increasing battery capacity, they are very useful for recharging the batteries between flights. We are continuing to add electronic devices (transponders, flarm, foot warmers, etc.) while on-board battery capacity is stagnant. In some gliders, like the DG80x, battery capacity is already at a critical level (and lithiums are not an option). If I ordered a new glider I would definitely go with the solar option (assuming it is available with Strobls closing).
Tom
Old November 26th 16, 10:54 PM posted to rec.aviation.soaring
Tom
Same problems with the DG400. If anyone has worked out an elegant solution to add separate instrument batteries, please reply privately to
Kevin no space soar AT gmail dot com
Flexible solar panel deal Soartech Soaring 5 June 15th 16 08:26 PM
Panel Mount Digital Volt Meter Dan Marotta Soaring 26 December 4th 13 05:28 PM
sizing solar panel Udo Rumpf Soaring 18 February 17th 06 01:36 AM
Panel volt meter Bob C Soaring 10 January 13th 05 12:00 PM
Thin flexible solar panels Eric Greenwell Soaring 11 November 28th 03 04:35 PM
