F18's wearing out faster than planned
Old August 19th 08, 08:00 AM posted to rec.aviation.military.naval,rec.aviation.military
Tiger
Default F18's wearing out faster than planned
http://www.strategypage.com/htmw/htn.../20080716.aspx
Hornets Hurting
July 16, 2008: The U.S. Navy has found that both their older F-18C
Hornet fighters, and their newer F-18E "Super Hornet" are wearing out
faster than expected. This was sort of expected with the F-18Cs, which
entered service during the late 1970s and early 80s. These aircraft were
expected to last about twenty years. But that was based on a peacetime
tempo of operations, with about a hundred carrier landings (which is
hard on the airframe) per year. There have been more than that because
of the 1991 Gulf War (and the subsequent decade of patrolling the no-fly
zone) and the war on terror. So to keep enough of these aircraft
operational until the F-35 arrives to replace them in the next decade,
new structural components (mainly the center barrel sections) are being
manufactured. This is good news for foreign users of the F-18C, who want
to keep their aircraft operational for longer.
The F-18E entered service about a decade ago, and was supposed to last
6,000 flight hours. But the portion of the wing that supports the pylons
holding stuff (bombs, missiles, equipment pods or extra fuel tanks) is
now expected to be good for no more than 3,000 flight hours. The metal,
in effect, is weakening faster than expected. Such "metal fatigue",
which ultimately results in the metal breaking, is normal for all
aircraft. Calculating the life of such parts is still part art, as well
as a lot of science. Again, unexpectedly high combat operations are the
culprit. One specific reason for the problem was the larger than
expected number of carrier landings carrying bombs. That's because so
many missions flown over Iraq and Afghanistan did not require F-18Es to
use their bombs or missiles.
The navy is modifying existing F-18Es to fix the problem, which is a
normal response to such situations. Sometimes these fixes cost millions
of dollars per aircraft, but this particular fatigue problem will cost a
lot less to fix. The wing metal fatigue problem does not occur with the
older F-18s (the A, C and D models) because, while they are also called
F-18s, they are not the same as the F-18 E, F and G models. That's
because, when the navy decided to build a replacement for the earlier
F-18, they found they could get away with calling it an upgraded F-18
model. Thus, instead of it being called the F-24 (the next number
available since the start of the Department of Defense's standard
designation system in 1962) it could be called the F-18 E and F. While
the F-18F looks like the original F-18, it is actually quite different.
The F-18E is about 25 percent larger (and heavier) than the earlier
F-18s, and had a new type of engine. By calling it an upgrade, it was
easier for the navy to get the money from Congress. That's because, in
the early 1990s, Congress was expecting a "peace dividend" from the end
of the Cold War, and was slashing the defense budget. There was a lot of
commonality between the two F-18s, but they are basically two different
aircraft. Thus when used more heavily than expected, they developed
metal fatigue in different parts of the airframe.
F18's Returning Ned Edwards Aviation Photos 0 June 28th 08 11:20 PM
F18's on Takeoff Ned Edwards Aviation Photos 0 June 28th 08 11:17 PM
faster 182? Dan Luke Piloting 26 February 21st 07 02:40 PM
faster 182? Dan Luke Owning 27 February 21st 07 02:40 PM
Looking At RAS Faster B. Iten Soaring 10 April 6th 04 10:21 PM
