Using 2 monitors with FS9
Old December 21st 04, 07:26 PM
Joe C
Hello Don. I found a sub-D/DVI adaptor on Ebay for $1.95. From the
picture it looks like what I want. Its DVI connector plugs into the
DVI slot of the ATI Radeon card and the female end accepts the sub-D
connector from the cable coming from the monitor. I don't understand
how that would work, however, since the monitor accepts ANALOG and the
DVI output of the ATI card I thought was digital. I must be missing
something.
BTW, the monitor came yesterday and boy did it come in a BIG box. It
was delievered by 2 UPS guys!
When I took it out of the box, it didn't look too good. The monitor
glass had all kinds of condensation on it after being brought into the
house. The outside temp was about 10 degress yesterday. After warming
up the display and deguassing it, it looked much better.
Joe C.
On Fri, 17 Dec 2004 15:36:33 -0600, "Don Parker"
Joe C wrote:
Thanks Don for your quick response. The new 22" monitor is an IBM
ThinkVision C220P which I thought was digital but I just checked and
see that it is DVI-A so I guess this all goes out the window. Rats!
A digital/ana converter is dirt cheap, just a little guy that goes in
between the plug & socket. I only paid $9 extra to Dell when I got my XPS
system almost two years ago, so I could use my Sony 19" and old Mag 15" (put
it on the digital out w/adapter) CRT's.... Your new IBM 22" and a 19"
secondary would be dy-no-mite!! Do it!! You won't look back...............
Old December 21st 04, 09:44 PM
Don Parker
something.
You got it right! The adapter not only matches the plugs, but it converts
the digital to analog for your monitor - there is some degradation to the
signal, but for most applications you'll never notice....
Just for future reference, let the monitor warm up to room temp BEFORE
turning on. The condensation can cause some fireworks in the high voltage
section (among others if a drop or two gets in between the wrong pins of an
IC) - and your 22" crt probably has in the neighborhood of 30,000 volts just
inching to burn it's own path to ground!!
Old December 22nd 04, 12:13 AM
Peter Duniho
"Don Parker" wrote in message
something.
No, you both have it wrong.
When a video card allows a DVI output to be adapted to a regular VGA/analog
output, it's simply matching form factors. The video card itself will emit
analog signals out the DVI port. All the adapter does is connect the
appropriate output wires on the DVI pot to the appropriate output wires on a
VGA-compatible output.
The signal is no more degraded than it would otherwise be using regular
analog output to the monitor.
There are genuine DVI-to-analog converters, but there's no way you're going
to find one for $1.95 (nor is it likely that you need one).
an IC) - and your 22" crt probably has in the neighborhood of 30,000 volts
just inching to burn it's own path to ground!!
Since condensed water vapor is unlikely to contain any electrolytes, or much
in the way of any impurities at all for that matter, it's likely to be as
good an insulator as the air around the monitor.
Maybe if you live right next to an ocean or something, there might be enough
ambient salt to allow the water to conduct. But otherwise, while I think
it's always a good idea to let stuff come to ambient temperature and to
allow any condensation to evaporate, I wouldn't worry too much about getting
any short-circuits from condensation.
Pete
FS: Custom molded in ear monitors Andre Products 0 January 7th 04 01:39 AM
Custom molded in ear monitors Andre Owning 0 January 7th 04 01:38 AM
FS: Custom molded in ear monitors! Andre General Aviation 0 January 7th 04 01:38 AM
Pros & cons of TFT monitors in flightsims? Alan Cameron Simulators 7 October 27th 03 02:57 PM
FS 2002 Multiple Monitors Hugh Roberton Simulators 1 September 22nd 03 01:49 PM
