Another test trick with Lycoming belt driven charging systems is to drive the alternator only with a 1/2 hp or more hand held electric motor instead of using the engine. The direction of rotation isn't critical. If you want to have "variable" speeds, put a cone pulley on the motor. This makes it a lot easier and safer to work around. Disadvantages are getting access if your cowl doesn't split, but of course that is always a problem. Recognize though that in service the alternator spins probably close to 10,000 RPM. |
Similar Threads | ||||
GEM 1200 Problem | Jim Kaufeld | Owning | 11 | March 22nd 04 03:54 AM |
A problem in the Military ? | Nick Jade | Military Aviation | 54 | March 15th 04 07:59 PM |
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Home Built | 78 | December 3rd 03 09:10 PM |
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Owning | 77 | December 3rd 03 09:10 PM |
Garmin fixes moving waypoint problem -- almost | Jon Woellhaf | Instrument Flight Rules | 6 | November 28th 03 05:29 PM |
