#21
Comm noise
Yup, and typically you shut one transceiver off (in the RF sense) and
connect the antenna directly to the other transceiver with a switch. Both this technique and the duplexer are rather difficult to achieve when you are talking ten watt transceivers being isolated in a small device from a microvolt receiver. For years hams have used coaxial switches to switch antennas between HF rigs, but doing it at VHF presents its own set of technical problems. Google Dow-Key to see the moosieness (?) of a coax switch. Jim A Nav only antenna doesn't transmit, which is why they can be shared easily. It's possible to share comm antennas, but you need either a transmit switch or duplexer of some type to protect the receiver. |
Comm noise
"RST Engineering" wrote in message
m... Yup, and typically you shut one transceiver off (in the RF sense) and connect the antenna directly to the other transceiver with a switch. Both this technique and the duplexer are rather difficult to achieve when you are talking ten watt transceivers being isolated in a small device from a microvolt receiver. For years hams have used coaxial switches to switch antennas between HF rigs, but doing it at VHF presents its own set of technical problems. Google Dow-Key to see the moosieness (?) of a coax switch. The FAA does it on the other end on the same frequencies. The actual device that does it is not very large either. It's about 2-3" square and about an inch tall. I've never seen it on an airborne application, but that's not to say it isn't practical or even that it hasn't been done. Personally I wouldn't want it as it just gives you another few single points of failure. I'd rather have two antennas and two sets of cables. |
Comm noise
"Mike" writes:
I'd rather have two antennas and two sets of cables. Agreed, especilly for a hand-held. Add an antenna for it, period. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
#24
Comm noise
"RST Engineering" wrote Google Dow-Key to see the moosieness (?) of a coax switch. I see all kind of neat products there, but I still don't understand what you are getting at, as far as moosieness (whatever that term is or implies) and its relation to a coax switch. I know I shudder every time I contemplate having to make up a well and properly shielded connection. I would assume that is the direction you are going, with trying to keep the correct clearances between the conductor and the shield, with all of the components in a switch, and still be well shielded. Or not? g -- Jim in NC |
Similar Threads | ||||
Comm 120 | Tri-Pacer | Owning | 2 | July 31st 07 04:59 PM |
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets | Jim Macklin | Piloting | 26 | January 13th 07 12:06 AM |
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets | Jim Macklin | Instrument Flight Rules | 15 | January 13th 07 12:06 AM |
360 Comm | Tri-Pacer | Home Built | 3 | August 5th 06 04:09 PM |
Prop noise vs. engine noise | Morgans | Piloting | 8 | December 24th 03 03:24 AM |
