Surecheck Avionics Trafficscope VRX
Has anyone used any of the passive traffic alert systems that are out on
the market today? I saw this one on AircraftSpruce sight .4 AMU's instead of the usual .8 AMU's. I did some searching and found out that this particular model is discontinued hense the half-price sticker. Has any of you flown with this kind of device and how do you think it does for spotting traffic I flew with a guy last year that had this exact model in his 182 and it seemed to work well. Here is a link to the specs: http://www.surecheck.net/library/ts_datasheet.pdf Jon Kraus '79 Mooney 201 4443H @ TYQ |
Hi!
I've got it in my plane, and it works as advertised. However, you have to spend some time with it to learn how to interprate it's readings. There is no azimuth, so you only know relative distance, not bearing to the threat, and even this can vary a bit. Also, transponder only outputs when interrogated by ATC radar or TCAS aircraft in the area, so if only one radar and no other aircraft, I guess it can take up to 10-12 secs to see a change in range. Anyway, as soon as you find a good place for the antenna, the unit works as it should. I am generally happy with mine, however mounting the antenna is not as easy as they claim. It seams sensitive to where it is mounted. I bought it at full price a year ago, so if you can get it for half, go for it! Frode "Jon Kraus" skrev i melding ... Has anyone used any of the passive traffic alert systems that are out on the market today? I saw this one on AircraftSpruce sight .4 AMU's instead of the usual .8 AMU's. I did some searching and found out that this particular model is discontinued hense the half-price sticker. Has any of you flown with this kind of device and how do you think it does for spotting traffic I flew with a guy last year that had this exact model in his 182 and it seemed to work well. Here is a link to the specs: http://www.surecheck.net/library/ts_datasheet.pdf Jon Kraus '79 Mooney 201 4443H @ TYQ |
The guy I rode with had it stuck on the dash of his 182... I didn't see
if he had the antenna anywhere but sticking up in the back of the unit just like in the picture. Are you saying that the antenna that comes with it might not work that great or that you need to remotely position the antenna? Anyway thanks for the reply... Jon Kraus '79 Mooney 201 4443H @ TYQ Frode Berg wrote: Hi! I've got it in my plane, and it works as advertised. However, you have to spend some time with it to learn how to interprate it's readings. There is no azimuth, so you only know relative distance, not bearing to the threat, and even this can vary a bit. Also, transponder only outputs when interrogated by ATC radar or TCAS aircraft in the area, so if only one radar and no other aircraft, I guess it can take up to 10-12 secs to see a change in range. Anyway, as soon as you find a good place for the antenna, the unit works as it should. I am generally happy with mine, however mounting the antenna is not as easy as they claim. It seams sensitive to where it is mounted. I bought it at full price a year ago, so if you can get it for half, go for it! Frode "Jon Kraus" skrev i melding ... Has anyone used any of the passive traffic alert systems that are out on the market today? I saw this one on AircraftSpruce sight .4 AMU's instead of the usual .8 AMU's. I did some searching and found out that this particular model is discontinued hense the half-price sticker. Has any of you flown with this kind of device and how do you think it does for spotting traffic I flew with a guy last year that had this exact model in his 182 and it seemed to work well. Here is a link to the specs: http://www.surecheck.net/library/ts_datasheet.pdf Jon Kraus '79 Mooney 201 4443H @ TYQ |
Hi!
In my Arrow, the front window angles more than in a Cessna I believe, so the antenna would barely fit. I wanted to position the unit a bit farther back on the glareshield, then the antenna would not fit at all, so I bought an extension with a suction mount. Works fine with that, though they recommend not using it if you can fit it with the antenna on the back on the glareshield. I've had a couple of weird readings lately, so I'll try to make it fit oon the back again. Frode "Jon Kraus" skrev i melding .. . The guy I rode with had it stuck on the dash of his 182... I didn't see if he had the antenna anywhere but sticking up in the back of the unit just like in the picture. Are you saying that the antenna that comes with it might not work that great or that you need to remotely position the antenna? Anyway thanks for the reply... Jon Kraus '79 Mooney 201 4443H @ TYQ Frode Berg wrote: Hi! I've got it in my plane, and it works as advertised. However, you have to spend some time with it to learn how to interprate it's readings. There is no azimuth, so you only know relative distance, not bearing to the threat, and even this can vary a bit. Also, transponder only outputs when interrogated by ATC radar or TCAS aircraft in the area, so if only one radar and no other aircraft, I guess it can take up to 10-12 secs to see a change in range. Anyway, as soon as you find a good place for the antenna, the unit works as it should. I am generally happy with mine, however mounting the antenna is not as easy as they claim. It seams sensitive to where it is mounted. I bought it at full price a year ago, so if you can get it for half, go for it! Frode "Jon Kraus" skrev i melding ... Has anyone used any of the passive traffic alert systems that are out on the market today? I saw this one on AircraftSpruce sight .4 AMU's instead of the usual .8 AMU's. I did some searching and found out that this particular model is discontinued hense the half-price sticker. Has any of you flown with this kind of device and how do you think it does for spotting traffic I flew with a guy last year that had this exact model in his 182 and it seemed to work well. Here is a link to the specs: http://www.surecheck.net/library/ts_datasheet.pdf Jon Kraus '79 Mooney 201 4443H @ TYQ |
Jon: What is an "AMU"? Thanks for the edification. Leo
Jon Kraus wrote: Has anyone used any of the passive traffic alert systems that are out on the market today? I saw this one on AircraftSpruce sight .4 AMU's instead of the usual .8 AMU's. I did some searching and found out that this particular model is discontinued hense the half-price sticker. Has any of you flown with this kind of device and how do you think it does for spotting traffic I flew with a guy last year that had this exact model in his 182 and it seemed to work well. Here is a link to the specs: http://www.surecheck.net/library/ts_datasheet.pdf Jon Kraus '79 Mooney 201 4443H @ TYQ |
On 05/13/06 06:52, Leo wrote:
Jon: What is an "AMU"? Thanks for the edification. Leo Google gave me this: http://www.mooneyevents.com/acronyms.html The site is specific to Mooneys, but the term applies to all aircraft ;-) Jon Kraus wrote: Has anyone used any of the passive traffic alert systems that are out on the market today? I saw this one on AircraftSpruce sight .4 AMU's instead of the usual .8 AMU's. I did some searching and found out that this particular model is discontinued hense the half-price sticker. Has any of you flown with this kind of device and how do you think it does for spotting traffic I flew with a guy last year that had this exact model in his 182 and it seemed to work well. Here is a link to the specs: http://www.surecheck.net/library/ts_datasheet.pdf Jon Kraus '79 Mooney 201 4443H @ TYQ -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
An AMU is an Aviation Monetary Unit. 1 AMU = $1000. Expressing the
money we spend on our expensive hobby as an AMU insead of saying thousands of dollars is a way of hiding from the better half how much flying these things really costs... Also, saying AMU just sounds cheaper... Just in case she too happens to be reading these newgroups... :-) Jon Kraus '79 Mooney 201 4443H @ TYQ Leo wrote: Jon: What is an "AMU"? Thanks for the edification. Leo Jon Kraus wrote: Has anyone used any of the passive traffic alert systems that are out on the market today? I saw this one on AircraftSpruce sight .4 AMU's instead of the usual .8 AMU's. I did some searching and found out that this particular model is discontinued hense the half-price sticker. Has any of you flown with this kind of device and how do you think it does for spotting traffic I flew with a guy last year that had this exact model in his 182 and it seemed to work well. Here is a link to the specs: http://www.surecheck.net/library/ts_datasheet.pdf Jon Kraus '79 Mooney 201 4443H @ TYQ |
Similar Threads | ||||
Surecheck trafficscope - any experiences or opinions? | Andrew Gideon | Products | 3 | January 3rd 05 07:26 AM |
Proxalert R5 Proximity alerter | Andrew | Soaring | 0 | June 1st 04 03:14 PM |
Surecheck TrafficScope Pirep? | Marco Leon | Owning | 30 | October 21st 03 02:44 PM |
Surecheck TrafficScope Pirep? | Marco Leon | Piloting | 20 | October 13th 03 03:39 PM |
Surecheck TrafficScope Pirep? | Marco Leon | Products | 20 | October 13th 03 03:39 PM |
