#31
I passed the checkride, now need a good GPS and passenger headset
The statement that using a GPS is a "skill" is almost humorous. Using
a GPS demands only slightly more skill than turning on an electric light. I rather strongly beg to differ. The simple stuff ("direct to" and follow the purple line) requires little skill, but getting into the more esoteric modes (which can happen by accident) can really increase the pucker factor if you are relying on the box. I'm disagreeing with the view expressed in the post that initiated this thread that a brand new private pilot "needs" a GPS--i.e., that it is a "necessity." I agree with you there. GPS is not a necessity. I will say it's real nice in complex airspace though. But nice is... well, just "nice". Seat cushions are nice too. The most important display unit VFR is the WAPDU (Wide Angle Plexiglass Display Unit) Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
#32
vincent p. norris wrote:
The statement that using a GPS is a "skill" is almost humorous. Using a GPS demands only slightly more skill than turning on an electric light. Exuse me for cutting in but I have to utter a hearty "Bull****!". I was out of flying for 15 years after flying every day for various part 135 outfits. Let me tell you, today's panel looks different from what I was used to. I climbed into a retrofitted C-172 for my BFR last year when I started flying again and found that although I had several hundred hours in C-172s that I couldn't figure out the panel. I could fly the airplane just fine... but I couldn't figure out how to change frequencies, etc. The primary radio in that airplane happened to be a Garmin 430. I ended up taking dual *just* on the Garmin; then buying a manual and installing a GPS sim on my computer. I learned how to do a few things with it but don't fly enough any more to retain the lesser used functions. I probably only use 10% of what that GPS is capable of doing. Don't tell me that operating the GPS doesn't require skills. I say that while still remembering how to navigate with just a map and the compass and I can still fly a very decent ILS or ADF approach. Those require skills too... just different ones. -- Mortimer Schnerd, RN VE |
#33
Agreed.
Seems to me that if you want to fly beyond local pattern hops, you need to be skilled in basic navigation (i.e. using a map and compass), and an electronic navigation system (GPS if you have it, something less like a VOR or ADF if you are flying something with lesser equipment.) On the other hand, you should be proficient in using whatever is installed in the aircraft or perhaps it should be turned off. Mortimer Schnerd, RN wrote: vincent p. norris wrote: The statement that using a GPS is a "skill" is almost humorous. Using a GPS demands only slightly more skill than turning on an electric light. Exuse me for cutting in but I have to utter a hearty "Bull****!". I was out of flying for 15 years after flying every day for various part 135 outfits. Let me tell you, today's panel looks different from what I was used to. I climbed into a retrofitted C-172 for my BFR last year when I started flying again and found that although I had several hundred hours in C-172s that I couldn't figure out the panel. I could fly the airplane just fine... but I couldn't figure out how to change frequencies, etc. The primary radio in that airplane happened to be a Garmin 430. I ended up taking dual *just* on the Garmin; then buying a manual and installing a GPS sim on my computer. I learned how to do a few things with it but don't fly enough any more to retain the lesser used functions. I probably only use 10% of what that GPS is capable of doing. Don't tell me that operating the GPS doesn't require skills. I say that while still remembering how to navigate with just a map and the compass and I can still fly a very decent ILS or ADF approach. Those require skills too... just different ones. |
#34
You're not "cutting in," you're joining the discussion. Welcome. I was out of flying for 15 years after flying every day for various part 135 outfits. I had a somewhat similar experience. I could not afford to fly at my expense when I got out of the marine corps after six years and went back to college then had a mortgage and four kids to feed. Seventeen years later my two boys got out of school and enlisted. Suddenly there was money left at the end of the month! I could afford to start flying again. The difference was amazing. I had never seen a VOR or an ILS. I had never heard "...radar contact seven miles north of...." I had to learn the new instruments and the new rules. But it was a hell of a lot easier! IFR flying was now child's play compared to what it had been in the days of Acock ranges and ADF approaches. In a similar way, GPS has made it a hell of a lot easier. I probably only use 10% of what that GPS is capable of doing. True of me, too. But that's all the new private pilot who ''needs" a GPS would use, too. vince norris |
#35
Vincent,
I probably only use 10% of what that GPS is capable of doing. True of me, too. But that's all the new private pilot who ''needs" a GPS would use, too. Right. Just like running the engine at 10 percent power, closing the doors only 10 percent, landing well only 10 percent of the time and so on. -- Thomas Borchert (EDDH) |
#36
I agree. Anyone who thinks using a GPS correctly in the context of aerial
navigation is like turning on an electric light needs some dual on the basics of what constitutes proper flight instruction . I take particular notice of the following comment from the same source; "And if you have been flying long, you know that a new pilot with a GPS will quickly become dependent and will never develop pilotage skills. It's common knowledge that many recently trained pilots have not learned to navigate well. It's often been discussed here." Whether this comment is true or false in its entirety isn't my main concern .. What concerns me is the first part of this comment which states a habit pattern as fact that I have not seen in properly trained pilots in all the years I've been associated with flight instruction. I totally disagree with the idea that new pilots using a GPS will quickly become dependent and will never develop pilotage skills. Any pilot properly trained will have been taught basic piloting skills and know how to use them. That pilot will also, if using a GPS, have been instructed in the proper use of a GPS in the TOTAL CONTEXT of the aerial navigation problem. That properly trained pilot will be using his/her GPS with all the backup associated with it's proper use. There is absolutely no basis in fact that I have seen anyway, that pre-supposes a new pilot will use a GPS at the expense of normal backup navigation skills. Any properly trained pilot will consider a GPS as just another tool to be used accordingly and ALONG WITH the other necessary navigation tools available to produce a safe flight. Now if we're talking improperly trained pilots........that's another story! :-)) Dudley Henriques "Mortimer Schnerd, RN" wrote in message . .. vincent p. norris wrote: The statement that using a GPS is a "skill" is almost humorous. Using a GPS demands only slightly more skill than turning on an electric light. Exuse me for cutting in but I have to utter a hearty "Bull****!". I was out of flying for 15 years after flying every day for various part 135 outfits. Let me tell you, today's panel looks different from what I was used to. I climbed into a retrofitted C-172 for my BFR last year when I started flying again and found that although I had several hundred hours in C-172s that I couldn't figure out the panel. I could fly the airplane just fine... but I couldn't figure out how to change frequencies, etc. The primary radio in that airplane happened to be a Garmin 430. I ended up taking dual *just* on the Garmin; then buying a manual and installing a GPS sim on my computer. I learned how to do a few things with it but don't fly enough any more to retain the lesser used functions. I probably only use 10% of what that GPS is capable of doing. Don't tell me that operating the GPS doesn't require skills. I say that while still remembering how to navigate with just a map and the compass and I can still fly a very decent ILS or ADF approach. Those require skills too... just different ones. -- Mortimer Schnerd, RN VE |
#37
aerial navigation is like turning on an electric light needs some dual on the basics of what constitutes proper flight instruction . I have a pretty good idea of what constitutes proper flight instruction, Dud; mine was courtesy of the United States Navy. I understand it's generally considered a fairly rigorous program. I take particular notice of the following comment from the same source; It's common knowledge that many recently trained pilots have not learned to navigate well. It's often been discussed here." Whether this comment is true or false in its entirety isn't my main concern. That is the essential notion being discussed here, Dud. You're changing the subject. And if it's not your main concern, why do you take particular notice of it? Any pilot properly trained will have been taught basic piloting skills and know how to use them. You're begging the question, saying a properly trained pilot has been properly trained. Duh! Why would a brand-new private pilot who was "properly trained," and has confidence in his ability to navigate by DR and Pilotage, think that the first thing he needs is a GPS? There is absolutely no basis in fact that I have seen anyway, that pre-supposes a new pilot will use a GPS at the expense of normal backup navigation skills. You seem to have it backwards. It's the GPS that is supposed to be the "backup." Any properly trained pilot….. Now if we're talking improperly trained pilots........that's another story! We are. Some young pilots I've talked with in recent years cannot get from here to there without using VORs. If they depend VORs to navigate in VMC, you expect me to believe they won't depend on GPS, which is even easier? I strongly suspect some young CFIs are not very good at pilotage either. Don't forget, Dud, that 50% of all CFIs are below average. ((:-)) vince norris |
#38
"vincent p. norris" wrote in message ... Anyone who thinks using a GPS correctly in the context of aerial navigation is like turning on an electric light needs some dual on the basics of what constitutes proper flight instruction . I have a pretty good idea of what constitutes proper flight instruction, Dud; mine was courtesy of the United States Navy. I understand it's generally considered a fairly rigorous program. I have no problem with Navair, and the training you have received or not received is not at issue here.What I'm addressing is your statement that asserts something as fact that I don't believe is fact based on my direct exposure to the environment in which you have chosen to assert yourself; that being the training environment from the instructor's side of the coin. The simple truth is that you have stated the following; " if you have been flying long, you know that a new pilot with a GPS will quickly become dependent and will never develop pilotage skills." ......and I take exception to that. It's simply not true enough to be presented as a glittering generalization like this. In my experience as an instructor over time, the exact opposite would be indicated unless the pilot in question was trained improperly. You are attempting to convey with this statement that a new pilot with a GPS is likely to become dependent on that GPS. My contention is that any properly trained pilot will use a GPS simply as one more available tool to be used in conjuction with other navigational skills, pilotage being one of these skills. I take particular notice of the following comment from the same source; It's common knowledge that many recently trained pilots have not learned to navigate well. It's often been discussed here." Whether this comment is true or false in its entirety isn't my main concern. That is the essential notion being discussed here, Dud. You're changing the subject. And if it's not your main concern, why do you take particular notice of it? I'm not changing the subject. The subject I addressed in my initial post was simply an opposition comment to your direct statement. My comment was direct, in context, and to the point. Any pilot properly trained will have been taught basic piloting skills and know how to use them. You're begging the question, saying a properly trained pilot has been properly trained. Duh! Quite to the contrary, it is YOUR statement that a new pilot who has a GPS in his/her navigational equation will become dependent on that GPS to the point of not developing normal navigational skills that begs the question; "has this pilot been properly trained?" I'm begging nothing. I'm telling you that any properly trained pilot will have been trained to use all the navigational skills especially the basics and the backups to the basics, and will have been taught to develop the habit patterns necessary to use those skills. For you to pre-suppose that the insertion of a GPS into such a pilot's navigational environment would cause that pilot to neglect all that he/she has been trained to do is in my opinion patently absurd on it's face. Why would a brand-new private pilot who was "properly trained," and has confidence in his ability to navigate by DR and Pilotage, think that the first thing he needs is a GPS? A "properly trained pilot" thinking the "first thing he needs is a GPS" is the oxymoron of the day. The fact is that NO properly trained pilot will NEED a GPS. The GPS, as I have sated for the properly trained pilot, will be simply an additional navigational tool to be used in conjection with whatever backup is necessary for that GPS to produce a safe flight under the conditions present concerning that flight. There is absolutely no basis in fact that I have seen anyway, that pre-supposes a new pilot will use a GPS at the expense of normal backup navigation skills. You seem to have it backwards. It's the GPS that is supposed to be the "backup." Actually, since I've been saying from the onset of this discussion that the GPS is in fact just one more navigational tool, it appears that it might be you who has things backwards :-) Any properly trained pilot... Now if we're talking improperly trained pilots........that's another story! We are. Some young pilots I've talked with in recent years cannot get from here to there without using VORs. If they depend VORs to navigate in VMC, you expect me to believe they won't depend on GPS, which is even easier? I have no doubt that there are pilots out here who rely on one basic system for navigation and that doing this is bad juju, be it VOR, ADF, of GPS for that matter. No one is arguing that issue. These pilots exist as we all know. I am arguing your statement that this type of pilot constitutes a majority as you indicate with your use of the phrase "a new pilot with a GPS will quickly become dependent" You are taking what I consider the exception and projecting that exception as the rule, and in my opinion, you are wrong. Hence the opening discourse on what constitutes proper training. I strongly suspect some young CFIs are not very good at pilotage either. I wouldn't argue this. Notice you correctly used the word "some". Don't forget, Dud, that 50% of all CFIs are below average. ((:-)) I'm sorry you have such a low opinion of flight instructors. Dudley Henriques |
#39
Dudley,
Don't forget, Dud, that 50% of all CFIs are below average. ((:-)) I'm sorry you have such a low opinion of flight instructors. Uhm, Vince is alluding to the surprise of President Roosevelt (I think) about the fact that 50 percent of the US population had (and have) a below-average intelligence. This, as Vince's statement, is inherent in the definition of "average" - well, not exactly, I know, but kind of, assuming an equal distribution around the average. -- Thomas Borchert (EDDH) |
#40
Thomas Borchert wrote: Uhm, Vince is alluding to the surprise of President Roosevelt (I think) about the fact that 50 percent of the US population had (and have) a below-average intelligence. Given that time frame, are you implying that the "dumb" ones immigrated from Europe to North America while the "smart" ones stayed in Europe? :-)) |
