AGC vs. ATC fuses in glider panels
Old February 15th 17, 07:33 PM posted to rec.aviation.soaring
jfitch
Default AGC vs. ATC fuses in glider panels
Can anybody shed some light on why manufacturers continue to use glass (AGC) fuses rather than blade type plastic (ATC) fuses in gliders? Is there a certification issue, is it simply inertia? Automotive, marine, heavy equipment, and pretty much everyone else has moved on to the ATC style. From personal experience, a high quality blade style holder is more reliable than the Bussman glass holder which seem to corrode over time. There are some intermediate amp values available in glass that are not in ATC, but this seems like a trifle.
Old February 15th 17, 07:42 PM posted to rec.aviation.soaring
AGC fuse holders are easier to mount on panel faces. One reason.
UH
Old February 15th 17, 08:00 PM posted to rec.aviation.soaring
JS
You called it: Inertia.
No need for fuses on the front of the panel.
5Z is working on a nice combo that uses blade fuses on the side of the panel.
A rectangular cut-out to access the fuses in one of these, mounted PowerPoles facing up inside the panel.
https://powerwerx.com/west-mountain-...05h-horizontal
Back to polishing,
Old February 15th 17, 08:02 PM posted to rec.aviation.soaring
krasw
UH
Yes! I would change to blade fuses if panel mounted solution existed. Maybe someone has found one?
Old February 15th 17, 08:14 PM posted to rec.aviation.soaring
jfitch
UH
I am finding plenty of panel mount fuse holders for ATC/ATO, mostly from LittleFuse but also Eaton/Bussmann. There seem to be both blocks of various sizes as well as individual stackable versions such as:
http://www.littelfuse.com/products/f...s/ato_fh2.aspx
The advantage of the latter is it is very compact, and the fuse blade holder itself it crimped onto the lead, so one less Faston connector to fail (but harder to disassemble).
Here is a rear mountable 6 circuit with Faston connections, not as compact:
http://www.littelfuse.com/~/media/co...ato-6-pole.pdf
Or this Eaton version:
http://www.cooperindustries.com/cont...fusepanel.html
In general, the block versions don't seem to be very compact.
Fuses on the panel, or not SF Soaring 41 November 18th 16 09:41 PM
Searching for fuses [email protected] Soaring 14 August 26th 15 01:43 PM
Fuses in general Tuno Soaring 19 December 11th 08 06:45 PM
Bussman Fuses kevmor Piloting 10 May 25th 07 03:25 AM
Bussman Fuses kevmor Piloting 2 May 22nd 07 09:28 PM
