AKperson wrote:
I just purchased a 172 and the previous owner removed a top mounted gps antenna. What is the recommended procedure for filling holes? He used silicone in the screw holes and a button type patch for the antenna hole. Sounds pretty good. When I removed the LORAN antenna from my old 150, I bolted an aluminum patch over the hole from the inside. I used small aircraft grade bolts in the existing screw holes. I then sealed it with white silicon -- it actually matched the paint pretty well. I also smeared silicon between the patch and the skin before bolting it in. All done as advised by the local A&P. George Patterson Why do men's hearts beat faster, knees get weak, throats become dry, and they think irrationally when a woman wears leather clothing? Because she smells like a new truck. |
Similar Threads | ||||
Fixing screw holes in fabric | Brian Huffaker | Home Built | 4 | May 21st 05 02:16 AM |
filling Oxygen tanks | Bruce McFadden | Piloting | 40 | January 3rd 05 03:25 AM |
Filling oxygen tanks | Bruce McFadden | Owning | 49 | December 28th 04 11:41 PM |
Case against airman was full of holes | Otis Willie | Military Aviation | 0 | September 25th 04 09:29 PM |
Lago Terramesh 13 (England & Wales) - holes in landscape? | Kevin Reilly | Simulators | 3 | November 11th 03 02:46 PM |
