#41
STF question
JJ Sinclair wrote:
I believe this shows that we should not fly M/C zero except in very light wind. Yes, as long as you have to use MC as a crutch to set speed so that you get max glide, the above is absolutely correct. Downwind you should set MC negative (if you can ) I believe the program in the SN-10 doesn't take into account the drift correction angle which was considerable with the 25 knot cross-wind I had on my final leg home. I was holding a good 10 degrees heading up- wind as the ship tracked Parowan. This gave me much more of a head- wind component and I believe the comuuter didn't compute on the 'real' heading that would be required to track the destination into a stiff cross-wind. What do you thing? I do not know what SN-10 does, but yes, cross wind component is very important if you worry about wind. Cheers, Henryk |
#42
STF question
On Mar 20, 9:35 am, JJ Sinclair wrote:
Another issue I found with the SN-10 happened on the last day at Parowan, last year. We had a stiff S/W wind at 25 knots with 3 turn areas. I has excess altitude as I entered the last turn area, which was down wind from Parowan. I penetrated until the computer said I was 1000 feet over final glide home and then made my turn. As soon as I finished the turn and centered up on the final leg, the computer said I would just make it! I lost my 1000 foot cushion in the turn (wind remained the same). What happened? Huh ? You gotta stop spinning the glider rounding the turn, can't use the "turnpoint camera" excuse anymore yaknow... I believe the program in the SN-10 doesn't take into account the drift correction angle which was considerable with the 25 knot cross-wind I had on my final leg home. I was holding a good 10 degrees heading up- wind as the ship tracked Parowan. This gave me much more of a head- wind component and I believe the comuuter didn't compute on the 'real' heading that would be required to track the destination into a stiff cross-wind. The SN10 certainly takes into account the wind direction (cross). No idea what went on above. Sometimes the reserve jumps UP, because we round turnpoints or AAT earlier than the nominal turnpoint or AAT point, but a reserve going DOWN is really very odd... Please email me any further detail ! See ya, Dave "YO" |
#43
STF question
Hi Dave,
I just checked my trace for the last day at Parowan and guess what? The computer didn't screw up, I did. I don't adjust the turn point when flying a turn area task, I simply keep checking on final 'altitude required' by clicking off the turn point (which is the center of the turn area). Well, I was tired, it had been a hard day at the end of 8 hard days straight and I forgot to 'click it off'. If I had turned early, the altitude required would have jumped up, but I flew past it and.......................I better stop trying to figure out what the SN-10 does, just concentrate on operating it correctly! Sorry for the incorrect post, I do love the SN-10, really! JJ The SN10 certainly takes into account the wind direction (cross). No idea what went on above. Sometimes the reserve jumps UP, because we round turnpoints or AAT earlier than the nominal turnpoint or AAT point, but a reserve going DOWN is really very odd... Please email me any further detail ! See ya, Dave "YO" |
Similar Threads | ||||
One more question... | john smith | Aviation Photos | 12 | October 6th 07 07:32 PM |
MRA Question | [email protected] | Instrument Flight Rules | 3 | April 16th 06 02:19 PM |
I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 06:39 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
