Gelcoat and solvents
Old May 12th 04, 05:16 PM
Nolaminar
Default Gelcoat and solvents
Are any solvents damaging to gelocat?
Xylene, lacquer thinner, gasoline, paint thinner?
GA
Old May 13th 04, 09:03 AM
Phil Jeffery
Yes
"Nolaminar" wrote in message
GA
Old May 13th 04, 01:59 PM
Robert Ehrlich
Phil Jeffery wrote:
Yes
GA
We routinely remove traces of glue from adhesive tape
with gasoline (100 LL), and those from mylar seals with
aceton without any damage to the gelcoat.
Old May 13th 04, 02:13 PM
Mark Zivley
WD40 works well on tape residue too.
Robert Ehrlich wrote:
Phil Jeffery wrote:
Yes
GA
Old May 13th 04, 02:57 PM
BllFs6
Phil Jeffery wrote:
For years I was a shade tree mechanic....fixing my cars, friends and families
And during engine rebuilds, I'd often use just gasoline and alot of elbow
grease to clean stuff up....
But you know what REALLY cleaned up stuff MUCH nicer, quicker, and easier than
gasoline? Not to mention being much safer and easier to work with?
Diesel fuel (and I suspect kerosene would be similiar).
Off hand you might think gas would be a much better solvent for getting grung
off...but the diesel was MUCH better and faster....at least on the stuff on and
in car engines...
So, maybe try diesel, and then use something like alchohol to remove the last
traces of diesel residue?
take care
Blll
Old May 13th 04, 05:15 PM
Pete Reinhart
Well,
Jet-A works like diesel and doesn't smell as bad.
Cheers!
"BllFs6" wrote in message
families
than
grung
on and
in car engines...
last
take care
Blll
Old May 13th 04, 06:04 PM
Eric Greenwell
If I had this question, I'd ask someone like Bob Gaines...smiley face
I'm sure all of them "damage" the gel coat, but perceptible damage
depends on how often and how much, and the condition of the gel coat to
begin with. My experience is occasionally cleaning of tape residue or
transfer adhesive (mylar seals) isn't a problem, even after 10 years, on
gel coat that is in good condition to begin with. Some polishes for gel
coat, like Lesonal, are petroleum based anyway (I think so, but someone
that has a can of this with the label still on it, please check!).
Under what circumstances did you want to use the solvents?
Eric Greenwell
Washington State
USA
Old May 16th 04, 11:15 PM
Mike Lindsay
In article , Mark
Zivley writes
Phil Jeffery wrote:
Yes
GA
The handbook for our DG202 specifically warns against using
petrol/gasoline for cleaning.
Mike Lindsay
