Aero Advantage Dual Pump
Old February 23rd 06, 03:20 PM posted to rec.aviation.owning
Default Aero Advantage Dual Pump
Am I the only one that still has the Aero Advantage Dual Pump
installed? I see that the AD to remove the pump has finally arrived:
http://dmses.dot.gov/docimages/p84/385862.pdf
This is a stupid AD, in my opinion. The reason for the AD is that both
chambers might fail at the same time. But, how is that any worse than a
single-chamber pump failing?
Fortunately, the FAA updated the AD to allow owners to retain the
monitoring system, but unfortunately, the FAA has not yet granted
FAA/PMA approval to Phoenix Group (www.aeroadvantage.com) to
manufacture the simple part that is needed to do the mod.
My choice of replacement will probably be yet another new style pump,
the Sigma-Tek AEON pump (http://www.sigmatek.com).
Interestingly, the guy at Phoenix Group (the company that took over
Aero Advantage) implied that they a solution to the original flaw and
still plan to bring an update to market, if they get financing. And,
they'd overhaul the old units.
Old February 27th 06, 04:13 AM posted to rec.aviation.owning
I still have one on my C172. The problem is the big 6 cylinder
engines induce a torsional vibration that the pump is resonant to.
This fatigues the shear point on the shaft and the pump can quit in
less than 100 hours when used with certain 6 cyl engines.
I have over 200 hours on my Aero Advantage pump but I am using a 4
cylinder Lycoming 0-320 and have had no problems.
I have had 3 Airborne pumps fail so far. Not a single one got to the
published Airborne TBO hours. One lasted 900 hours, one lasted 250
and one only lasted 50 hours. Is the Airborne pump better? Not in my
opinion unless you have a 6 cyl engine.
At least the feds are letting me keep the vacuum warning system.
Anybody got real world reliability data on the AEON pump yet?
John F
Old February 27th 06, 10:54 PM posted to rec.aviation.owning
If you're asking about the piston pump, I think not ready for prime
time yet - heard some reports of early failure.
The only reliable pumps are the oil-lubricated ones from Airwolf and
other vendors.
Saratoga Gear Retract Problem Yahoo! News Owning 16 November 29th 05 11:17 PM
Looking for a reversible fuel transfer pump [email protected] Home Built 13 April 12th 05 09:26 PM
Aero Advantage closing shop. Eric Ulner Owning 51 May 17th 04 03:56 AM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
Dual Chamber Vacuum pump Dave Butler Owning 0 August 8th 03 02:50 PM
