Outstanding Soaring: California Mojave, Owens Valley, Western NV- Labor Day Weekend
On Aug 26, 8:01*am, Alex wrote:
On Aug 25, 5:45*pm, WaltWX wrote: Take a look Dr Jack... Outstanding soaring weather Fri through Sun. *Lift rates 700-800fpm average... much stronger in those 10 per cent... It's a toss up between Fri and Sunday. *The Mojave Desert, Owens Valley and Western NV show full cu coverage bases 15,500 to 17,500. It appears to be dry enough that only isolated thunderstorms will form in the normal "hot spots". *Early trigger times also. I reviewed Dr Jack this afternoon with a long ago crew of mine, John Halcrow. *For Crystalaire, the pattern on Friday looks as good as I've ever seen it. *BL (thermal) max heights 17,500msl (of course cloud bases will limit altitudes to a little lower). I'm coming back out Saturday to give my 750 km triangle another try from Inyokern (please... leave me room for an 11:30am takeoff Walt Rogers, WX Walt, I ran a 4KM resolution RASP last night for AVENAL that goes 2 days out. It is centered on AVENAL, but covers the high desert area around Edwards and the S. Sierra and Owens Valley up to N. of Mono Lake. If I'm interpreting it right (which is highly open to question), it's saying Friday and Saturday, there should be good cumulus in the desert area in Region 12, *but it should *be drying out in Region 12 by *Sunday. *On Sunday, the better cumulus will be more up North in Region 11. *On Friday, there may be some higher level overcast from subtropical moisture coming in from the SW with some chance of OD along the coast range near Castle Peak and New Cuyama and over the S. part of the Sierras. The higher level overcast shows up on the Skew-T sounding forecasts on the RASP, *but not on the regular blipmaps. *This should be gone on Saturday and Sunday. *Would be interested in what you think about it. Also any pilot reports after the weekend is over would be interesting to hear to correlate with the forecast. http://alcald.homelinux.org/RASP/AVE...RASPtable.html Alex Caldwell Central Calif. Soaring Club Avenal, CA, USA- Hide quoted text - - Show quoted text - Well the forecast for this labor day weekend looks epic for the Sierras, much better than last weekend. High base cu along the whole length of the sierra on Saturday and accross the Great Basin as well on Sunday. Monday should be similar. |
Similar Threads | ||||
California Sierras /Western Mojave: Good to Great Soaring weatherWed-Fri 08/19 to 08/21 | WaltWX | Soaring | 4 | August 19th 09 04:45 AM |
R2505 restricted airspace...Owens valley. | fredsez | Soaring | 1 | September 23rd 08 06:00 AM |
R2505 restricted airspace...Owens valley. | fredsez | Soaring | 0 | September 23rd 08 05:22 AM |
Soaring in Owens Valley | Tuno | Soaring | 8 | August 24th 07 01:33 PM |
Owens Valley | E. Douglas Whitehead | Soaring | 1 | August 21st 07 05:44 AM |
