fly with ce silver badge question
Old August 20th 13, 02:47 AM posted to rec.aviation.soaring
Bob Cook[_2_]
Default fly with ce silver badge question
It says that the fly with ce is now approved for silver badge flights..
BUT....
If I am reading the rules correctly...it seems that you must also carry an
additional, approved, calibrated, pressure altitude recording device?
Is this the case? If so, what is the point of the fly with ce? As in
silver climb....and loss of altitude in silver distance?
Cookie
Old August 20th 13, 03:49 AM posted to rec.aviation.soaring
Papa3[_2_]
Short answer is that this WAS the case when GPS Position recorders were first approved and when the current approvals were posted to the IGC website. Kind of explains why the concept of GPS Position Recorders didn't exactly take off.
Under the October 2012 revision to the Sporting Code, GPS Position Recorders which provide only GPS altitude CAN be used on a standalone basis. SSA and other NACs are in the process of reviewing several models. FlyWitCE FR300 should be officially posted any day mow. Do carefully read section 4 and Annex C; there is a 100m additional margin required for flights documented using only GPS. More detailed answer when I'm on a proper keyboard and not this tablet.
Erik Mann
Old August 20th 13, 11:38 AM posted to rec.aviation.soaring
Bob Cook[_2_]
Erik...
Thanks.....I finally got to the correct sections of the sporting code and
the annex......
The SSA is misleading ....
So basically we just 100 meters to everything...
1100 meters for silver climb.........
3100 meters for gold climb
1% rule for silver distance...but 100 meters higher than that at finish...
etc..
Cookie
fir=
website.
exactly
take off. =20
Recorder=
a=
FR3=
an=
documente=
and
not this tablet.
Erik Mann
Bob Cook[_2_]
Erik...
the annex......
etc..
Cookie
fir=
website.
exactly
take off. =20
Recorder=
a=
FR3=
an=
documente=
and
not this tablet.
Erik Mann
Old August 20th 13, 04:37 PM posted to rec.aviation.soaring
Papa3[_2_]
Now that I'm on a real keyboard...
The IGC made it possible for standalone GPS Position Recorders to document Silver and Gold badges effective last October. However, it is up to the individual NACs to identify and approve specific devices in collaboration with the IGC's GFAC (the group that oversees all things GPS/Flight Recorder). As of right now, the SSA is in the final stages of getting approval for the FlyWithCE FR300 posted to the IGC Website. I know a couple of other countries are in the same boat.
Note that the devices that are currently up on the IGC Website were all approved under the prior rules which required the use of a separate Barograph. Some of those devices may be re-approved under the new rules.
Clear as mud?
P3
On Tuesday, August 20, 2013 6:38:15 AM UTC-4, Cookie wrote:
Erik...
the annex......
1% rule for silver distance...but 100 meters higher than that at finish....
etc..
Cookie
fir=
website.
exactly
take off. =20
Recorder=
a=
FR3=
an=
documente=
and
not this tablet.
Erik Mann
Silver Badge Camp - SoaringNV, Minden, Nevada Soaring NV[_2_] Soaring 0 July 5th 12 09:53 PM
Silver Badge! [email protected] Soaring 17 November 24th 08 03:12 AM
Bronze Badge question [email protected] Soaring 32 January 11th 06 09:19 PM
Silver Badge Fun (?) Mark Zivley Soaring 43 July 14th 03 07:52 PM
Silver Badge Fun (?) - real challenges? Nyal Williams Soaring 0 July 11th 03 04:45 PM
