Astir Locking Collars
Has anyone got any definitive documentation regarding the fitting of "thin"
shims on Astir wing spigots that are approaching the 5mm limit on collars I recall having something a few years ago, but unable to retrieve it Fully aware of the engineering logic of too thick shims and ball/spigot relationship |
On Sunday, August 25, 2013 3:57:26 AM UTC-7, Astir. wrote:
Has anyone got any definitive documentation regarding the fitting of "thin" shims on Astir wing spigots that are approaching the 5mm limit on collars I recall having something a few years ago, but unable to retrieve it Fully aware of the engineering logic of too thick shims and ball/spigot relationship Are you saying that the 'little balls' inside your locked lift fittings, have reached the bottom of the spigot 'groove' and the wings are not tightly secured to the fuselage and you are considering rectifying this condition using shims? |
The rotating collars are locking the wings correctly, the FM states there
needs to be a 5mm gap shown on the locking collar, which is now approaching The paperwork I had as far as I recall was from Grob to the UK air cadets who flew a fleet of Grob gliders, which stated that a thin shim could be placed onto the wing spigots to take up wear. In "little balls" At 12:41 25 August 2013, JJ Sinclair wrote: On Sunday, August 25, 2013 3:57:26 AM UTC-7, Astir. wrote: Has anyone got any definitive documentation regarding the fitting of "thin" shims on Astir wing spigots that are approaching the 5mm limit on collars I recall having something a few years ago, but unable to retrieve it Fully aware of the engineering logic of too thick shims and ball/spigot relationship Are you saying that the 'little balls' inside your locked lift fittings, have reached the bottom of the spigot 'groove' and the wings are not tightly secured to the fuselage and you are considering rectifying this condition using shims? |
I believe the approved fix for this is to install ball, of a larger diamiter.
Similar Threads | ||||
LS1 Tail locking spring | Andrew[_9_] | Soaring | 7 | September 24th 10 02:09 AM |
Winpilot pro and Ipaq 4700 locking up. | joesimmers | Soaring | 5 | July 17th 08 05:42 AM |
90 degree locking pliers? | B. Jensen | Home Built | 8 | October 3rd 05 06:50 PM |
New Wheel Locking Device | TM | Products | 2 | March 29th 05 04:07 PM |
Looking for 3/8 in-24 thread/low profile self locking nuts/ | Larry | Home Built | 3 | February 22nd 05 03:02 PM |
