Cockpit air vents
Old April 25th 08, 10:39 AM posted to rec.aviation.homebuilt
bartbrn
Default Cockpit air vents
Anyone know where I can get small adjustable cockpit air vents that
don't cost $80.00 a pop?
Thanks!
Bart
Old April 25th 08, 02:16 PM posted to rec.aviation.homebuilt
Gig 601Xl Builder
Thanks!
Bart
Can you be a little more specific?
Old April 25th 08, 07:50 PM posted to rec.aviation.homebuilt
John Kunkel
"bartbrn" wrote in message
If you're referring to "eyeball vents" it kinda depends on what you call
small. There are inexpensive plastic ones that are around 2.5" available
from hot rod sources like Vintage Air but for the aluminum billet type that
are half that size you might be stuck with aviation version.
Old April 25th 08, 08:09 PM posted to rec.aviation.homebuilt
Rich S.[_1_]
Flymart at OSH. Good reason to go and spend a thousand bucks for
transportation, accommodation, and recreation.
Rich S.
Old April 25th 08, 11:36 PM posted to rec.aviation.homebuilt
Charlie[_2_]
Thanks!
Bart
Van's A/C has surprisingly good prices on a lot of accessory items.
Their plastic eyeball by itself is $20; a complete kit is $33.
http://www.vansaircraft.com/cgi-bin/...ion-components
Charlie
Old April 26th 08, 02:21 AM posted to rec.aviation.homebuilt
bartbrn
http://www.vansaircraft.com/cgi-bin/...209162694-328-...
Exactly what I was looking for -- thanks! My apologies to all for not
being a little more size-specific -- 2.5" is just right. Can you
recommend some other good sites? I have Aircraft Spruce's catalog, but
I'm always looking for A/C-grade bolts and miscellaneous hardware.
Thanks again!
Bart
Old April 26th 08, 02:24 AM posted to rec.aviation.homebuilt
bartbrn
And I was looking for some NACA intake vents... thanks a third time!
Bart
Trailer Vents... Gary Emerson Soaring 1 February 25th 08 07:38 PM
Solar Vents JJ Sinclair Soaring 2 February 14th 08 01:36 PM
Cessna air vents Matt Owning 30 January 14th 06 12:53 AM
LS8 tank vents Flavio Formosa Soaring 1 June 1st 05 12:32 PM
C172 Air vents Matt Young Owning 8 July 2nd 04 12:53 PM
