Slingsby Kestrel trim speed C FFKQ ?
Old September 25th 18, 08:42 PM posted to rec.aviation.soaring
john firth
Default Slingsby Kestrel trim speed C FFKQ ?
The pic gives a good idea of the boom mounted tailplane fixture.
Next winter project for my PIK 20.
I note that the elevator shows the BGA required mod., a downward cusp added to
the Glasfluegel design.
This was supposedly to provide feel at high speeds; found it (1972)
to spoil the feedback and worse, to allow trimming only to 80 kts or so.
This was quite unacceptable to me in for contest. I removed the cusp
and found feel and trim speed now acceptable.
John Firth
Old September 26th 18, 01:52 AM posted to rec.aviation.soaring
C-FFKQ (42)
There was actually a mod on the Series 2 and later ships where the cusp was removed and an anti-balance tab was added.
My ship is a Series 1 with only the enlarged rudder as a modification.
I find the handling acceptable, so I won't cut off the cusp (although it might be nice to put in the anti-balance tab mod).
Seeking input on Glasflugel/Slingsby Kestrel [email protected] Soaring 2 September 12th 16 05:11 AM
Taxi calculator? (propeller type and speed, aircraft weight, taxi speed) John Doe[_4_] Home Built 54 March 30th 11 08:43 PM
Taxi calculator? (propeller type and speed, aircraft weight, taxi speed) John Doe[_4_] General Aviation 0 February 3rd 11 10:55 PM
Slingsby T-21 Nyal Williams Soaring 14 March 1st 07 08:28 AM
Slingsby Kestrel 19m Grant Johnson Soaring 1 July 27th 06 06:14 AM
