off airway MEA's
Old March 11th 07, 09:21 PM posted to rec.aviation.ifr
akiley
Default off airway MEA's
I'm wondering if there is a way to determine the minimum altitude
required for uninterrupted communication with ATC off airways? Do you
look at the closest airway and sort of interpolate the MEA? Do the
center and approach controllers have maps with these altitudes? I'm
assuming an MVA doesn't carry a communication guarantee.
I'm planning a flight over Canada that leaves the Detroit area, up the
Bruce Peninsula and back into the US in northern Michigan. I ended up
calling Toronto center on the phone, but it would be interesting to be
able to figure this out on my own. ... akiley
Old March 11th 07, 10:55 PM posted to rec.aviation.ifr
vincent p. norris
That might work fairly well in flat country, but not in mountainous
regions.
vince norris
Old March 13th 07, 08:38 PM posted to rec.aviation.ifr
Paul kgyy
No way that I know of. I've lost ATC over Indiana at well above
nearby MEAs when they vectored me off airway and then apparently
forgot about me. I would assume that since facilities are organized
around airways, off-airway communication would normally require a
higher MEA even in flat country.
Old March 15th 07, 10:48 PM posted to rec.aviation.ifr
cavedweller
This may be helpful:
http://bathursted.ccnb.nb.ca/vatcan/...rentTopic.html
GNS430 on the Airway [email protected] Instrument Flight Rules 66 February 16th 06 04:59 AM
Odd clearance -- airway given twice Roy Smith Instrument Flight Rules 15 September 20th 05 03:32 PM
FA: Jeppesen Airway Manual Binders raduray Aviation Marketplace 0 March 7th 05 12:05 AM
Airway emergency - what would you have done. JJS Piloting 25 May 20th 04 02:24 PM
Can ATC assign an airway if filed direct? Andrew Sarangan Instrument Flight Rules 26 March 4th 04 12:23 AM
