Eccentric cam wing assembly tools
Old November 7th 16, 07:15 PM posted to rec.aviation.soaring
Default Eccentric cam wing assembly tools
Very elegant solutions. I was in a hurry one day and just stuck a length of plastic rod (Nylon or Delrin? Not sure of diameter but maybe 2/3 of the wing pin?) in the overlapped main spar holes and pushed/pulled on the rod to lever the wings of my ASW 24 together the last few mm. Been doing it that way for 20+ years since.
It only works if the wings are within a few mm of being completely inserted in the fuselage. It's not like the Libelle over-center wrench that you could engage when the wings were very far apart. But IMHO, any device like this should only be used to snug the wings together the last little bit.
Chip Bearden
FS: Eccentric Assembly Tools SteveB_Z5 Soaring 18 December 16th 13 06:30 PM
FS: ECCENTRIC ASSEMBLY TOOLs SteveB_Z5 Soaring 17 March 22nd 13 07:40 PM
FS: Eccentric Assembly Tools SteveB_Z5 Soaring 0 July 27th 12 11:52 PM
FS: Eccentric Assembly Tools SteveB_Z5 Soaring 0 January 21st 12 05:37 PM
Wing assembly dollies Udo Soaring 1 December 2nd 10 02:51 AM
