Gaffers tape is a polyurethane over a cloth laminate and may not stretch the way you require.
Also much thicker. |
On Sunday, 9 August 2020 at 17:10:32 UTC-6, wrote:
Gaffers tape is a polyurethane over a cloth laminate and may not stretch the way you require. Also much thicker. Gaffer tape is designed specifically not to leave glue residue behind when removed (specifically useful eg. in the film industry, where tape has to be applied to carpets, clothing, sets etc.). It's basically less-sticky duct tape. I wouldn't use it on a glider, unless you have a phobia about glue residue. |
On Thursday, August 13, 2020 at 12:07:34 AM UTC-4, ProfJ wrote:
On Sunday, 9 August 2020 at 17:10:32 UTC-6, wrote: Gaffers tape is a polyurethane over a cloth laminate and may not stretch the way you require. Also much thicker. Gaffer tape is designed specifically not to leave glue residue behind when removed (specifically useful eg. in the film industry, where tape has to be applied to carpets, clothing, sets etc.). It's basically less-sticky duct tape. I wouldn't use it on a glider, unless you have a phobia about glue residue. I put mine on two seasons ago and it hasn't come off yet. I guess it has something to do with good surface preparation as well. Uli 'AS' |
Wing Tape | Craig[_2_] | Soaring | 0 | May 5th 11 05:09 PM |
Books on Military Rotary Wing to Civilian Fixed Wing Transition? | Greg Copeland | Piloting | 5 | May 2nd 07 03:23 AM |
Wing Tape - Does Thickness Affect Performance? | ContestID67 | Soaring | 87 | February 1st 07 03:24 PM |
Wing Tape - Does Thickness Affect Performance? | Charles McLaurin | Soaring | 2 | January 30th 07 06:00 PM |
Mylar tape wing seals - effect on wing performance | Simon Waddell | Soaring | 8 | January 1st 04 03:46 PM |
