Grob SB's
Old January 17th 19, 05:03 PM posted to rec.aviation.soaring
Alan Garside
Default Grob SB's
Anyone paid for access to the Grob web site for SB information. In
December
they introduced the charge but now have had to make it free as they are
required to make the information available to A/C owners. But guess what,
they don't want to refund those who have paid as it gives access to FM's
MM's even though there was no option just for SB's. Greedy or what!!
Old January 17th 19, 09:59 PM posted to rec.aviation.soaring
son_of_flubber
Default Grob SB's
On Thursday, January 17, 2019 at 12:15:04 PM UTC-5, Alan Garside wrote:
... Greedy or what!!
I'm glad that they still find it worthwhile to make ADs when needed.
Old January 17th 19, 10:03 PM posted to rec.aviation.soaring
Frank Whiteley
Default Grob SB's
Like to see a TN and parts to change the retracts to a fixed gear.
Old January 18th 19, 12:24 AM posted to rec.aviation.soaring
George Haeh
Default Grob SB's
Grob glider ADs & SBs at:
http://www.ltb-lindner.com/grob-saleplanes.html
Old January 18th 19, 01:35 AM posted to rec.aviation.soaring
Michael Opitz
Default Grob SB's
LTB Lindner has been asked that a number of times. Apparently,
they have no interest in doing so.
Old January 18th 19, 11:02 AM posted to rec.aviation.soaring
Martin Gregorie[_6_]
Default Grob SB's
How much, if anything is there in common between the fixed u/c mounting
structure in a Twin Astir and an Acro II?
Just a thought inspired by the apparent ease with which the early Libelle
201s could be converted from fixed to retractable u/c.
Martin | martin at
Gregorie | gregorie dot org
Old January 18th 19, 04:22 PM posted to rec.aviation.soaring
James Thomson[_2_]
Default Grob SB's
December
what,
Are you referring to SBs for pure gliders (G102, G103, G104) or motor
gliders (G109, G115, G120)? There are two completely separate support
organisations involved! Gliders have been supported by ltb-lindner since
2010, the motor gliders by the latest manifestation of Grob now called Grob
Aircraft SE. Two companies, two attitudes towards their customers.
Old January 18th 19, 04:55 PM posted to rec.aviation.soaring
Alan Garside
Default Grob SB's
It's motor gliders and I agree two completely different attitudes.
December
they are
guess
what,
to FM'
what!!
motor
support
lindner sinc
called Gro
customers.
Old January 18th 19, 08:20 PM posted to rec.aviation.soaring
Papa3[_2_]
Default Grob SB's
Completely different animals. A number of owners have investigated this, and it's not a simple issue at all. The structure is completely different as well as the mechanicals of the wheel, mounts, etc.
Several operators I know of have pinned the gear in the down and locked position. We'd all love to reshape the rear seatpan, but it's integral to the structure and would require an engineered solution.
Old January 18th 19, 09:14 PM posted to rec.aviation.soaring
Default Grob SB's
Libelle 201s could be converted from fixed to retractable u/c.
Fair enough. I've flown both Twin Astir and Acro IIs, so it seemed
possible that replacing the folding undercarriage with a fixed one on the
same attachment points would have been an easy job, and cheapish too,
since it could reuse tested structure in an, apparently, very similar
airframe.
I should have looked at Martin Simon's book "Sailplanes 1965-200" before
opening my trap: it describes a complex lay-flat retract system which
almost certainly could not have been easily replaced with fixed gear.
(Takes foot back out of mouth).
Martin | martin at
Grob 109 Brien Soaring 29 July 13th 19 02:22 PM
Grob Value? Frank Whiteley Soaring 0 February 7th 12 04:43 AM
Grob Bob O'Rilley Soaring 3 April 29th 05 07:22 PM
Grob 103 SL R.W. Carpenter Soaring 2 March 21st 04 10:21 PM
GROB 102 Vorsanger1 Soaring 4 July 11th 03 11:34 PM
