iPhone 5 vs iPhone 6 sunlight readability
Old March 22nd 16, 04:08 PM posted to rec.aviation.soaring
6PK
Default iPhone 5 vs iPhone 6 sunlight readability
Just curious how these two iPhones stack up against each other and or the Oudie2 or Del Streak5 in sunlight readability?
6PK
Old March 22nd 16, 10:04 PM posted to rec.aviation.soaring
jfitch
6PK
The iPhone 5 and 6 are near the same brightness, a little brighter for the 6. The 6 also has a little better anti-reflective coating. Del Streak is a different animal, having a transflective screen. I have an Avier which I think is the same display as an Oudie2 (the products look like identical hardware). On paper, the Avier/Oudie is 800 or 1000 nits, while an iPhone 6 is only 580 or so. But side-by-side, they look pretty similar in readability, except for when looking into the sun: Your iris closes and the apparent brightness of all of them diminishes, the iPhone suffering more than the Oudie.. A shade does not help, it is not a reflectance problem. With the sun behind you, they are similar. The iPhone screen has so much more resolution and crispness, it makes up for a lot. I have run an iPhone 5s and iPhone 6 Plus/iGlide against an Avier/XCSoar/Winpilot/SYM side by side in the cockpit for a number of flights. With bright sun behind me, I need to remove my sunglasses to see the iPhone clearly, while I can still just make out the Avier..
I find the 6 Plus more readable than the 5s, even though the screen brightness is the same there is a whole lot more screen and therefore a whole lot more light coming out. The 6 is a little bigger than the 5, the 6 Plus is a lot bigger.
Old March 22nd 16, 11:54 PM posted to rec.aviation.soaring
6PK
6PK
The iPhone 5 and 6 are near the same brightness, a little brighter for the 6. The 6 also has a little better anti-reflective coating. Del Streak is a different animal, having a transflective screen. I have an Avier which I think is the same display as an Oudie2 (the products look like identical hardware). On paper, the Avier/Oudie is 800 or 1000 nits, while an iPhone 6 is only 580 or so. But side-by-side, they look pretty similar in readability, except for when looking into the sun: Your iris closes and the apparent brightness of all of them diminishes, the iPhone suffering more than the Oudie. A shade does not help, it is not a reflectance problem. With the sun behind you, they are similar. The iPhone screen has so much more resolution and crispness, it makes up for a lot. I have run an iPhone 5s and iPhone 6 Plus/iGlide against an Avier/XCSoar/Winpilot/SYM side by side in the cockpit for a number of flights. With bright sun behind me, I need to remove my sunglasses to see the iPhone clearly, while I can still just make out the Avier.
Thank you for the response. Interestingly I 'been running an Avier/WinPilot combination for the fourth season now as well. If it wasn't for the outdated airspace data I would just keep on going. (I did come up with a fix but not a very good one through). Thinking about alternates for the next season at this point.
Experimented with XcSoar, SeeYou Mobil, looking for something better, as with all it's faults WinPilot still wins out at least for me.
iGlide update for iPhone 6 (4.7 inch) and iPhone 6 plus (5.5 inch) Sean Fidler Soaring 29 March 9th 15 03:24 AM
True Sunlight Readability Richard[_9_] Soaring 0 September 23rd 12 03:41 PM
Oudie vs Streak sunlight readability Max Kellermann Soaring 14 July 7th 11 04:04 PM
Garmin iQue 3600a -- sunlight screen readability? Chuck Instrument Flight Rules 7 March 24th 05 10:00 PM
Garmin iQue 3600a -- sunlight screen readability? Chuck Piloting 17 March 24th 05 10:00 PM
