Battery charging C172
Due to a prolonged period of non use the 24V battery went flat on my
C172N. Is there any way a charger can be connected through the external power point rather than the hassle of removing cowls to connect battery charger alligator clips. It could be handy to connect a trickle charger ocassionaly during long periods of non use? Arthur |
a trickle charger ocassionaly during long periods of non use I don't mean to hijack your thread; I think this is relative. Talk about a coincidence! I also have a November model. When I plug in the yellow "jumper" tool, the gyros spool up as though the master is turned on. I would attach alligators from the charger to the external power point, through the yellow "jumper" tool, but i don't want to leave the gyros spinning for hours while the battery charges. How can I charge the battery without the gyros spinning? (with the cowl on) Maybe someone here knows both answers. TIA |
rowntree wrote:
Due to a prolonged period of non use the 24V battery went flat on my C172N. Is there any way a charger can be connected through the external power point rather than the hassle of removing cowls to connect battery charger alligator clips. It could be handy to connect a trickle charger ocassionaly during long periods of non use? Arthur Not positive about the 172N, but most external power plugs are designed to deliver current to the starter, not the battery. I've seen a few different designs. With some you need to leave the master off to start, some you don't. One thing they did have in common is that they typically bypassed the battery, making the connection unsuitable for battery charging. There should be a schematic for the external power plug in the flight manual. You should have a look. John Galban=====N4BQ (PA28-180) -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200801/1 |
If you have a cigarette lighter, the hole left after its removal just
exactly fits a 2.1mm power jack such as the Mouser #163-4302 or the Jameco #151590. The mating power plugs are in the same general area of the catalog. The mated pair costs about $2. "hobby shack" used to carry them; I'm not sure if they still do. Wire the power jack to the clock circuit. The clock uses a fuse/breaker directly off the battery and does not go through the gyros, master switch, or any of that. However, you have to limit the current of the trickle charger to less than that fuse/breaker or it will trip it instantly. Jim -- "If you think you can, or think you can't, you're right." --Henry Ford "rowntree" wrote in message ... Due to a prolonged period of non use the 24V battery went flat on my C172N. Is there any way a charger can be connected through the external power point rather than the hassle of removing cowls to connect battery charger alligator clips. It could be handy to connect a trickle charger ocassionaly during long periods of non use? Arthur 163-4302 |
One potential problem in this set up is if the orginal
Cessna clock circuit has be modified. On my 172, someone in the past rewired the clock to be on the switched side of the master contactor. I'm guessing it was to prevent the clock from running down the battery during long periods of non-use. You can tell by the fact that the clock stops when the master switch is turned off. Anyway, I left the clock wiring like it was and simply added a fused lead with 3 prong "tailer light" type connector to the battery terminals. The connector was mounted with a couple of large tie-wraps to the external power connector housing. Now, just open the aux power door, and plug in the float charger. "RST Engineering" wrote in message ... If you have a cigarette lighter, the hole left after its removal just exactly fits a 2.1mm power jack such as the Mouser #163-4302 or the Jameco #151590. The mating power plugs are in the same general area of the catalog. The mated pair costs about $2. "hobby shack" used to carry them; I'm not sure if they still do. Wire the power jack to the clock circuit. The clock uses a fuse/breaker directly off the battery and does not go through the gyros, master switch, or any of that. However, you have to limit the current of the trickle charger to less than that fuse/breaker or it will trip it instantly. Jim -- "If you think you can, or think you can't, you're right." --Henry Ford "rowntree" wrote in message ... Due to a prolonged period of non use the 24V battery went flat on my C172N. Is there any way a charger can be connected through the external power point rather than the hassle of removing cowls to connect battery charger alligator clips. It could be handy to connect a trickle charger ocassionaly during long periods of non use? Arthur 163-4302 |
Thanks, Jim. I have been looking for something like this, though for a
different purpose. I hate the cigarette lighter outlet but I need it for portable GPS power. If you so much as sneeze on the current setup it may break the connection and interrupt the power. It's also butt ugly. It does bring up a couple of questions for me. 1) How can I find out how much power the Jameco 151590 can handle. I can't find anything in the POH that tells me how big of a circuit breaker the cig. lighter is on, but I assume it's a whopper. (I actually have the old cig. lighter somewhere and it looks like you could light a cigar with it.) 2) Especially if I don't have to rewire to another (lower amperage) breaker, this would be a trivial change, right? Nothing more than a logbook entry from a cooperative A&E? Tom RST Engineering wrote: If you have a cigarette lighter, the hole left after its removal just exactly fits a 2.1mm power jack such as the Mouser #163-4302 or the Jameco #151590. The mating power plugs are in the same general area of the catalog. The mated pair costs about $2. "hobby shack" used to carry them; I'm not sure if they still do. Wire the power jack to the clock circuit. The clock uses a fuse/breaker directly off the battery and does not go through the gyros, master switch, or any of that. However, you have to limit the current of the trickle charger to less than that fuse/breaker or it will trip it instantly. Jim |
-- "If you think you can, or think you can't, you're right." --Henry Ford "T. McQuinn" wrote in message ... Thanks, Jim. I have been looking for something like this, though for a different purpose. I hate the cigarette lighter outlet but I need it for portable GPS power. If you so much as sneeze on the current setup it may break the connection and interrupt the power. It's also butt ugly. No you don't need the ciggie lighter jack in the airplane. Two ways of proceeding. One, the sanitary way, cut the ciggie plug off and rewire it to a nice small 2.1mm plug. Two, get yourself a ciggie jack and make a patch cord from your gps ciggie plug to a 2.1mm plug. It does bring up a couple of questions for me. 1) How can I find out how much power the Jameco 151590 can handle. I can't find anything in the POH that tells me how big of a circuit breaker the cig. lighter is on, but I assume it's a whopper. (I actually have the old cig. lighter somewhere and it looks like you could light a cigar with it.) Jameco is notoriously short on specifications in their catalog. Mouser, however, has the manufacturer's data sheet showing the connector to be rated at half an amp at 12/24 volts. The keep-alive breaker (clock, radio memory, etc.) can be up to 5 amps by regulation, and most of us throttle it back down to an amp or two with a smaller breaker. My suspicion is that little connector could stand a couple of amps in short circuit mode until the breaker popped in fault mode. I'd NEVER use the same circuit that the old ciggie lighter used for a couple of reasons. One, it isn't direct to the battery so you could never use it for trickle charging. Two, who needs 15 amps of aux power unless you are trying to run a ham rig with lots of transmit power. 2) Especially if I don't have to rewire to another (lower amperage) breaker, this would be a trivial change, right? Nothing more than a logbook entry from a cooperative A&E? Even IF you rewire it to another breaker, it is a minor (logbook) modification by my standards. BTW, FAA policy is clear on this. It is the INSTALLING A&P's decision as to whether a modification is major (337 & field approval) or minor (logbook entry). Clearly, hanging an O-470 on a C-150 is a major mod. Wiring a small circuit breaker by THIS A&P's decision is not. Jim Jim |
Have your mechanic wire up a cig lighter plug that is hot even though
the master is off. Comes in handy for charging various stuff when airplane camping. You can also charge the airplane battery by putting a small solar panel on the top of the panel and plugging it into the cig lighter. rowntree wrote: Due to a prolonged period of non use the 24V battery went flat on my C172N. Is there any way a charger can be connected through the external power point rather than the hassle of removing cowls to connect battery charger alligator clips. It could be handy to connect a trickle charger ocassionaly during long periods of non use? Arthur |
Just go to Radio Shack and get a cig lighter socket from them. Have the
mechanic mount it under the panel on copilots side. I've had one for years and I have a 3-1 splitter plugged in also. Right now I have the GPS and satellite radio plugged in. T. McQuinn wrote: Thanks, Jim. I have been looking for something like this, though for a different purpose. I hate the cigarette lighter outlet but I need it for portable GPS power. If you so much as sneeze on the current setup it may break the connection and interrupt the power. It's also butt ugly. It does bring up a couple of questions for me. 1) How can I find out how much power the Jameco 151590 can handle. I can't find anything in the POH that tells me how big of a circuit breaker the cig. lighter is on, but I assume it's a whopper. (I actually have the old cig. lighter somewhere and it looks like you could light a cigar with it.) 2) Especially if I don't have to rewire to another (lower amperage) breaker, this would be a trivial change, right? Nothing more than a logbook entry from a cooperative A&E? Tom RST Engineering wrote: If you have a cigarette lighter, the hole left after its removal just exactly fits a 2.1mm power jack such as the Mouser #163-4302 or the Jameco #151590. The mating power plugs are in the same general area of the catalog. The mated pair costs about $2. "hobby shack" used to carry them; I'm not sure if they still do. Wire the power jack to the clock circuit. The clock uses a fuse/breaker directly off the battery and does not go through the gyros, master switch, or any of that. However, you have to limit the current of the trickle charger to less than that fuse/breaker or it will trip it instantly. Jim |
Not sure what's up here but Thunderbird refuses to let me quote Jim's
reply normally................ Thanks, the 'sanitary' way (remove the cig. lighter and replace with something decent) is what I have in mind. The parts shipped from Jameco today so now I need to find out if my friendly A&P will really let me do some of the work. I guarantee you he's too busy to do it himself. My situation here is a nightmare as far as maintenance goes. To even get on the grounds of my county airport you have to pass signs that tell you nobody from the outside is allowed to do work on planes there without their express permission. But I know a guy ten minutes away who might be willing to work with me for a reasonable fee. I haven't been to the plane yet but I imagine I have the typical circuit breakers. Maybe the new connector could just be wired to an in-line fuse and connected to the existing cig. lighter wiring. But that will be up to what the guy signing off on the job wants to see! Tom |
Similar Threads | ||||
Charging System Gremlin | [email protected] | Owning | 9 | May 8th 06 08:41 PM |
Basic battery charging question | [email protected] | Soaring | 28 | April 10th 06 03:12 PM |
Charging? | PaulaJay1 | Owning | 25 | February 2nd 05 06:03 AM |
Cessna 210 charging problem | John Clonts | Owning | 9 | July 14th 04 03:08 PM |
Charging for Wings safety seminar? | Marty Shapiro | Piloting | 19 | June 23rd 04 05:28 PM |
