On Wed, 13 Oct 2004 04:39:47 GMT, Matt Young
wrote: Ok, a curious question just popped in my mind. Say that one was flying IFR in a piston single, maybe a 172 or 182. While enroute, either in actual or above a cloud layer, the engine fails. Will the windmilling prop keep the vacuum pump going enough to make the AI and DG usuable during descent through the clouds, or will the gyros keep spinning fast enough long enough to make the vacuum pump irrelevant? Your 're going to get answers all over the spectrum, but my take would be it might happen, but don't count on it to save your bacon. IOW, I'd not count on them working, or staying accurate which is _far_worse_ than not working when you are in the clouds. There are many variables such as the actual engine, prop, and vacuum pump combination as well as best glide speed. Its been my experience (which may not be typical) that a wet pump will do better with the low RPM than the dry pump. This is assuming you still have RPM which with a catastrophic failure you probably won't. In my particular airplane which has a wet pump and a constant speed prop, once the instruments are spun up even vacuum at idle (which is well below the minimum) will keep the AI and DG working. The AI stays accurate. The DG will start precessing but slowly although it does hold well with a prolonged idle on the ground. Actually it's close to being in tolerance. With full vacuum I don't have to reset it during a 3 to 4 hour flight. So, I'd expect to see the vacuum instruments "on mine" hold for some time, but even knowing them as well as I do, I'd still depend on partial panel and consider any use out of the vacuum instruments a bonus. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Similar Threads | ||||
Wet vs Dry Vacuum Pump | Fastglasair | Home Built | 1 | December 15th 04 05:17 PM |
Remove oil seal from vacuum pump adapter on Lycoming IO320 HOW????? | Ron | Home Built | 2 | February 24th 04 04:34 PM |
Tiny vacuum pump | Jim Weir | Home Built | 41 | January 24th 04 05:42 AM |
IVO props... comments.. | Dave S | Home Built | 16 | December 6th 03 11:43 PM |
Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 07:09 PM |
