Speed wing extensions
I have just recently extended my C model speed wings. I removed the
Original wing bow tips and added 48 inches of lift to each wing with flat tips. The situation now is I have a good bit of wash out. Enough to where when the tail of the plane is lifted to where the she would be in level flight, the wing tip actually has a little negative angle of attack. The plane flies fine but a little more tail down than I like. My next thought is to remove the extra 12 inches of wing to reduce the negative angle a bit. Anybody out there got any constructive experience or ideas, I be interrested to get your opinion. Thanks Walt |
Similar Threads | ||||
USB connectors/extensions for 396 XM antenna | [email protected] | Owning | 9 | May 14th 07 08:11 AM |
DG-1000 undercarriage collapses and inadvertent extensions ? | Bernie[_2_] | Soaring | 24 | May 1st 07 02:14 PM |
Glider Weight/Wing Loading and determing speed for best L/D for a given weight | 65E | Soaring | 3 | January 26th 06 09:26 PM |
Why are delta wing designs reputed to lose speed during turns? | Air Force Jayhawk | Military Aviation | 2 | September 25th 03 12:50 PM |
Wing Extensions | Jay | Home Built | 22 | July 27th 03 12:23 PM |
